Where do i put double sided tape when installing the RS Front LIP???
Ok, i have a replica of the RS front lip (aka the oem front sedan lip found on the 2002 civic lx sedan sport edition)
anyone know precisely where double sided tape should be applied? i want it secured but i dont want tape in places where it'll cause fitment to be a problem.
it's exactly like this lip optionjdm sells(note it's not really a type-r lip..optionjdm is just stuipd)
http://optionjdm.com/item.asp?cID=24&scID=33&PID=67
i put the honda aero lip on my car, it had spaces marked out where you put the tape on and it was in the same places that i pointed out to you up there...it just 3m molding tape
the squares arent the length of tape, its just showing you where to put it...you can put however long strips you want
Shinier than yours, meatbag
Making brakets > Tape...I think taking the extra time to make a few extra brackets will pay off when you have to part out your car someday....but thats just me...
You dont have to use tape, you can just mount it on and hold it with 2 screws at each end. That's what I was told with my type r lip. If you hold the lip too tight (taping it down), if you hit anything with the lip, you have more of a chance it will crack since it wont be able to flex.
the plan is to use the method that is close to stock as possible...that means, i'll be using screws on the underside just like the oem lip but the top part is supposed to be taped onto the bumper to reduce gaps....
also, i dont want to skip out on the tape because i dont want the thing rattling around...
EDIT: I just noticed your in Western Canada......if your from Vancouver you can take a look at my setup and I'd be happy to help with installing your lip
Tape makes a gap, a gap filled with tape.....1/2 of the reason I decided to go tapeless was to make it fit closer to the body.......you cant move or rattle my lip if your life depended on it......if your worried about vibration a few postage sized pieces in the right spot will cure that......tape works well..it's just not the best solution as its removal is just about the worst thing I can think of spending an afternoon doing..
the lip is already painted...i'll prollly try to install it on the weekend..
crowtoo
May 11, 2015 06:50 PM
