Sponsored by:
Sponsored by: CARiD
Excessive vibration from Ingalls Torque Damper
Old Aug 14, 2006
KINGCHILE's Avatar
KINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to allKINGCHILE is a name known to all
I installed my torque damper today and the only thing i really noticed was that the car had alot of vibration. When the car is idle its shakin pretty bad, my hood rattles from all the vibration. Has anyone else had this problem? If so how did you fix it? I need some troubleshooting help here. Help me out guys.
I set the damper at 15mm as it said on the directions and place the washers and rubber rings in the right place as well. Please help the vibration is annoying.
here is what it looks like installed.
Old Aug 14, 2006
Da1lyDr1ver's Avatar
extra vibration from a torque dampner is normal. think about it, you're stiffening up the engine and transfering the access movement the motor makes directly into the body of the vehicle. its pretty much the same as getting polyurathene motor mounts.
Old Aug 14, 2006
KINGCHILE's Avatar
but is it normal for the hood to rattle, i understand a lil but this is alot. Can anything be done to reduce the vibration?
Old Aug 14, 2006
01HonderCivic's Avatar
Don't be a n00b, search ftw
Does it only vibrate at idle? Or thru the entire rev range?
Old Aug 14, 2006
civicvtec1ps's Avatar
Search and Learn
Yup, normal.
ESMM is worse than Torque damper.
Old Aug 14, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Originally Posted by civicvtec1ps
Yup, normal.
K20 swap + Esmm is worse
Old Aug 14, 2006
TeLLy's Avatar
Yes, it's an Acura EL
I've got the Ingalls ETD installed on my car as well, there's a noticable amount of vibration on idle, but it's tolerable in my car. I saw a thread on Honda-Tech where someone put a little sound dampener on the chassis where the mount bracket goes (for us around the upper strut mount bolts), on a suggestion from Ingalls. Couldn't hurt to try.
Old Aug 14, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
Take some pics of your install.
Mine vibrates, but not to the extent that you are talking about and I'm on 12mm setting.
Old Aug 14, 2006
KINGCHILE's Avatar
+REPPED
Old Aug 14, 2006
Does that mean it worked?
Old Aug 14, 2006
KINGCHILE's Avatar
no it just means i appreciate the info on trying to reduce the vibration. i just got back from work, havent had anytime to work on it.
Old Aug 14, 2006
you can also adjust the hood so it closes tighter. my moms accord would vibrate like a **** and its stock. i just loosened those rubber stopper and now its nice and tight.
Old Aug 14, 2006
rice4lyfe's Avatar
rice4lyfe will become famous soon enough
wouldnt that lower the height of the hood when closed?
Old Aug 14, 2006
ya but not if you just do it a little bit. it would be raised slightly but will be tighter.
cferry7
Oct 3, 2015 04:33 PM
Tedverseti
Sep 29, 2015 05:41 PM
Wariogamer
Sep 29, 2015 09:49 AM
rovafa2002
Sep 28, 2015 06:57 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
