Sponsored by:
Sponsored by: CARiD
ALIGNMENT KIT
Old Feb 27, 2002
TOOLOWCIVIC's Avatar
ALIGNMENT KIT
I ordered a front alingment kit for my car. I just received it and it is just two longs screws and two bults. Is this what it should be. It is the Eibach kit from Tirerack. Also how do I put them on.
Old Feb 27, 2002
VNlilMAN's Avatar
The Standard One
i'm guessing you got the front kit and not the rear. you usually need the rear more then you need the front but ya the fronts are cheap.. anyways, to answer your question, they replace a bolt that holds the strut... go here... http://www.specprod.com/PERF_DIR/PER...J_HON01_5.HTML
Old Feb 27, 2002
Thanks for the info It really helped.
Old Feb 27, 2002
Hondasport01's Avatar
Hondasport01 is an unknown quantity at this point
I got the Eibach kit from tire rack it's cool. Stick the bolt through the top bolt hole on the bottom of the strut, turn it to get the desired camber. EZ
Old Feb 27, 2002
Thanks I gues I'll give it a try tomorrow. What about the back alignment kit? I am going to order those next week. Is it easy to install?
Old Feb 27, 2002
VNlilMAN's Avatar
The Standard One
http://www.specprod.com/PERF_DIR/PER...J_HON01_4.HTML
a lil harder then the front but shouldn't be hard at all...
Tedverseti
Sep 29, 2015 05:41 PM
Wariogamer
Sep 29, 2015 09:49 AM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
TheRiddicles
Sep 21, 2015 01:28 AM
