Sponsored by:
Sponsored by: CARiD
Old Feb 20, 2002
JBlazeVA's Avatar
JBlazeVA is an unknown quantity at this point
use the tire calc feautre...
Old Feb 20, 2002
Player1's Avatar
Player1 is an unknown quantity at this point
I want to know this too. I'm even questioning if lighter wheels with a bigger diameter could still slow you down. You know how if you're spinning around on a chair with your arms sticking out and you pull your arms in you spin faster? Well, you're still the same mass... I'm wondering if the same effect applies on wheels.
Anyway, I'm pretty sure 16" wheels aren't going to be a problem. If you're worried, maybe look into the lightweight wheels.
Old Feb 20, 2002
Player1's Avatar
<< i know my speedometer will be off, and that will get taken care of, but i mean the extra weight and size of the tire, like how much power will that drain? >>
You probably won't have to worry about it if you get the right sized tires. Whoever is installing will give you some advice on this.
Maybe this link will help?
Try this as well
Player1
