Sponsored by:
Sponsored by: CARiD
stroker kit ?
Old Feb 18, 2002
phoboy408's Avatar
phoboy408 is an unknown quantity at this point
stroker kit ?
I just wanted to know how the stroker kit works. And, does anybody know when it will come out?
Old Feb 18, 2002
Bridge's Avatar
Bridge is an unknown quantity at this point
I'm not 100% sure on this but it gives your engine a bigger displacement, thus more hp.
Old Feb 18, 2002
antidote11's Avatar
antidote11 is an unknown quantity at this point
A Stroker Kit hooks you up with Camshaft, Piston Rings, Pistons, and Connecting rods.
Here's one just for example.....JUN Stroker Kit
Old Feb 18, 2002
Bridge's Avatar
How much hp?
Old Feb 18, 2002
PerfectD3's Avatar
PerfectD3 is an unknown quantity at this point
Varies with the size increase, the size of the engine (4,6,8), and to what extent the stroke kit is carried out with. Also, what other things you do while the car is apart (coatings, polishing, balancing, blueprinting, etc)
Old Feb 18, 2002
phoboy408's Avatar
Thanks for the info u guys. But does anybody know when one will come ouT?[IMG]i/expressions/moon.gif[/IMG] if one does come out, I might jump on that, then a supercharger.
Old Feb 19, 2002
NoBottleJustThrottle's Avatar
NoBottleJustThrottle is an unknown quantity at this point
A good friend of mine that knows way too much about cars said, with a stroker kit on our cars..expect to see our hp right close to 180hp
Old Feb 19, 2002
IonRays's Avatar
IonRays is an unknown quantity at this point
im just wondering if u can use the D16 strokers for d17s
alot peeps says strokers breakdown often and not worth it on honda motors ..
Old Feb 19, 2002
PerfectD3's Avatar
No you can't use the D16 stroker for the D17 because in simplest terms the D17 is a stroked out D16. Stroker kits as long as they are installed properly will last as long as the original engine components would have.
Old Feb 23, 2002
SLiCKGreeK's Avatar
SLiCKGreeK is an unknown quantity at this point
damn a stroker kit sounds pimp..maybe ill get that first before a turbo...but does any1 know if its comming out and whos making it???????????????????????
Mad Dog Tannen
Oct 19, 2016 08:12 PM
Tedverseti
Sep 29, 2015 05:41 PM
Hutch1051
Sep 29, 2015 09:20 AM
anubis62
Sep 27, 2015 12:56 AM
beanhead
Sep 24, 2015 12:04 PM
