metal and metal grinding noise...
for some reason every year around this time my car always tend to make this metal and metal grinding noise coming from the front right side wheel. i know i have to turn my rotors. is there another way i can fix this? is something loose? the honda dealership says they can fix it for 150 bucks. is there another shop i can goto for a cheaper price?
any help is appriciated. Thanks.
Care to specify a little more? RF wheel doesn't help.
I'll fix it for $149.99, but it would help if you told us what.
If you have to turn the rotors, then just buy new ones, and replace the pads.
If you already have metal-metal on the brakes, plan on calipers too.
yep Boil's got the cure. unless you got a friend at a shop that can turn rotors for next to zero dollars, just buy new rotors and pads. if you're gonna spend $150 you could score both rotors and pads if you mail ordered or got a discount somewhere local.
if you haven't tried it doing a quick brake job its pretty simple, if you were to get rotors, pads, and all the work done @ the dealer it would cost probably $250-300 for the front brakes alone including the labor. just grab the parts and follow the DIY i'm sure you'll end up much better afterwards
Bonobo
Oct 2, 2015 06:58 PM
Bruce2
Sep 27, 2015 08:45 PM
duhwubwub
Sep 10, 2015 11:00 AM
tommycanada
Sep 5, 2015 04:59 PM
