Sponsored by:
Sponsored by: CARiD
M3 mirror led promlem
Old Sep 17, 2005
03CivicEX4Door's Avatar
03CivicEX4Door is an unknown quantity at this point
I bought m3 mirrors off of ebay and i installed them according to the diy, everthing worked fine, Then i notice my blue led's arn't working one burn't out on driver side mirror so i check everthing, seem's fine a few days go by and passenger side no blue led's working. so i check everthing again and still nothing. So i contact seller, tell them the situation and send them back. few weeks i get replacement's. Install them wire the same as befor. I checked everthing blue led's and yellow led's working correctly. I got to get something to eat them wire up power for mirrors. think everthing is ok, a few hrs later i get ready to leave so i check everthing no blue led's at all none working. then when i start driving i notice one working on drivers side and 2 on passengers side then the quit working again. Next day i chacked everthing seems ok. Now i only have 1 blue led working on drivers side, so i disconected everthing and say forget it. any idea's on why they keep burning out? I saw a post on how to take apart m3 mirrors but i can't find it again can any one find it. i also saw on their that you can replace led's any one know excactally how to do that?
Old Sep 19, 2005
diskreet's Avatar
1st off i had them and they are crapola.
to fix the blue LEDS go buy a bunch (6) from radioshack (~3.6 volt) BLUE!!!
hold a well heated soldering iron on the back of the board that holds the LEDS and remove the old ones. install new blue leds. done. i did it before i scrapped the whole thing cause the mirrors are useless.
the leds they give you are absolutly terrible!
Old Sep 20, 2005
AlienX's Avatar
AlienX will become famous soon enough
there is prob no resistor connected to the LEDs. LEDs are diodes, if they do not have a load connected to them (ex. resistor) they will burn out due to the fact that too much amps are running in. Just replace them with some nice new LEDs and make sure to properly resist the amps/voltage.
Old Sep 20, 2005
ragingSPAM's Avatar
I just burnt my tongue
^^ yup...u need to add resistors or get new LED's which can handle the amperage of the lighting
Old Sep 20, 2005
diskreet's Avatar
they come with resistors. im 100% serious the problem is the LEDs are that cheap and crappy. replace them
Old Sep 23, 2005
how do i take apart the mirror so i can replace them?
Old Sep 23, 2005
diskreet's Avatar
pull the mirror off gently, then start unscrewing! Thats it.
h4ldol
Apr 24, 2017 08:16 PM
Mad Dog Tannen
Oct 19, 2016 08:12 PM
frank_kleng
Sep 29, 2015 10:55 PM
carid
Sep 28, 2015 10:13 AM
MichaelLW
Sep 14, 2015 07:15 AM
