Sponsored by:
Sponsored by: CARiD
18's don't fit, please help!!!
Old Jan 23, 2002
SiRacer's Avatar
SiRacer is an unknown quantity at this point
Hey guys,
I just put on a set of 18" Focals with 215/35/18 Toyos and they don't fit right. I mean they fit on the car, but when I turn the wheel, they rub quite a bit. Is this normal, or am I doing something wrong. I am not sure what to do, so please let me know. And by the way, I still only have stock suspension.
Thanks for the help
[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Jan 23, 2002
black2k1vtec's Avatar
black2k1vtec is an unknown quantity at this point
what is the offset??
Is your car lowered??
Old Jan 23, 2002
1028CiViC's Avatar
1028CiViC is an unknown quantity at this point
guy 18 inch is too big man~
Old Jan 23, 2002
mykel115's Avatar
mykel115 is an unknown quantity at this point
Shave the wheel well
Old Jan 23, 2002
1028CiViC's Avatar
ahha good idea.~
Old Jan 23, 2002
SiRacer's Avatar
No the car isn't lowered, I don't think I could lower it. I am not sure on the offset, I think it +42. I know it is a front wheel drive wheel, my friend had them on an Integra.
Old Jan 23, 2002
rhyno's Avatar
rhyno is an unknown quantity at this point
yeah, need to know how much your car is dropped but even that shouldn't matter. 215/35/18 is actually slightly smaller than factory. i am riding on 215/40/18 with about a 2 3/4 inch drop and have absolutely no problems.
Old Jan 23, 2002
mykel115's Avatar
If you have 7.5 offset or width of the rims. Chance your tire will rub agains your fender. You need to cut your fender and dont forget to repaint it
Old Jan 23, 2002
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
I have 215/35ZR18 tires on my ride......... no rubbin/problems at all, its not lowered either!!!
Old Jan 23, 2002
SneakerPimp's Avatar
SneakerPimp is an unknown quantity at this point
what is the width on your wheels?
Old Jan 24, 2002
rhyno's Avatar
once again, mine are 7.5 offset, and no probs..
Old Jan 24, 2002
0100010's Avatar
0100010 is an unknown quantity at this point
Probably 42mm offset with 8" wide rims. Are only the rears rubbing? If so, you just need to roll the rear fender, or shave some of it off. If its the front that's rubbing, then the offset is probably 48mm or more. In which case you can roll the front fenders(a little), or possibly take out your wheel wells.
Old Jan 24, 2002
slam2k1civic's Avatar
slam2k1civic is an unknown quantity at this point
well all i have to say is that i have 18" rims and i dont come close to rub and i am selling my rims to put 19"
Old Jan 24, 2002
trevor's Avatar
trevor is an unknown quantity at this point
ALRIGHT check it,,,,,,,,,, The exact same thing happend to me,,,,,,,,
the wheels only rub when the car is IN THE AIR,,,,am i right????????????????
when you drop the car back down they wont rub,,,,,,,,
are they rubbing on the side strut tower??????? inside the wheel well right??????
just use a die grinder and shaave a little of that black goopy crap off of the strut housing and drop the car back down
you will be fine.....
the only way they will rub is if you catch air,,,,i mean litteraly jump your car,,,,,,then the wheels will stop....but you will hopefully never abuse your car like that....so therfore you will be fine.
damn.............hope that helped
[IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG][IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Jan 24, 2002
Blacatoe's Avatar
Blacatoe is an unknown quantity at this point
Hey SiRACER !!! Those aren't the F10's your having a problem with is it? I was planning on get the F10 but now you've got me thinking. Do you have a coupe or a sedan? I drive a Sedan, and I planned on going with the 18's.
Old Jan 24, 2002
GreenVenom's Avatar
GreenVenom is an unknown quantity at this point
have 18's on mine and lower with eibach pro kit no problems 215 35zr 18. check your fender!
GreenVenom
Old Jan 24, 2002
trevor's Avatar
yes alot of people have 18's on here w/ no problems.......(me).......
let us know what happends........
Old Jan 24, 2002
Mokushi's Avatar
Mokushi is an unknown quantity at this point
The major question you need to ask yourself is, "Did I buy rims that are 18x7 or 18x7.5?" If you bought the 18x7.5's, then chances are that your wheels are rubbing because the rims are just too wide for the given offset that you got. You got pretty much two options; (1) return/sell your rims to get a size that fits correctly or (2) roll/shave your fenders/wheel wells.
Old Jan 25, 2002
Diznavis's Avatar
Diznavis is an unknown quantity at this point
maybe this is a dumb question, but do you have splash guards on your car?
Old Jan 25, 2002
i have 18x7.5 with a 42mm offset and it works great so check your offset if you have any thing lower than a 40offset thats why its rubing.
Old Jan 25, 2002
Will 18x7.5 with a 45 offset fit?
Old Jan 25, 2002
FamilyMan's Avatar
FamilyMan is an unknown quantity at this point
I am having all kinds of problems trying to lower my 4 Door EX. I have posted a thread and need help. My question here is how do you "shave your wheel wells?" Roll the metal, cut it ...or what? I had the camber kit installed and the full alignment done and now my right rear is rubbing. I have 17x7s and run 215/45/17s. I have a lot of metallic popping sounds coming from the rear end. It sounds like my car is going to fall apart. The H&Rs are not made for the 4Dr EX. Eibach, Neuspeed et all have one kit for all 2001/2 Civics. H&R said that some cars have one strut longer than another on the back end. Maybe mine is. Don't know yet. I am going to find a rubber spring seat that will work for my unit and raise the back end about .75 to 1" to even out the drop. I can't figure out a way to lower the front anymore. Just be careful who does your work. My car is all fragged now. When I pulled out the rear seat today to try and find the noise, I had some tools under my seat banging around and found that the shop did not install the washer over the grommet on top of the strut. Fixed all that and still have the metallic popping sounds. Only now they are worse plus the tire is rubbing. Good grief! The strut boot looks crooked on the right rear and when I install the spring seat I will figure out if I have the two unequal strut problem and figure out why my car sounds so crap. Also, even though my wheels are aligned perfectly, by car still tends left, so maybe my right rear is causing the problem.
cmart1209
May 29, 2015 04:52 AM
boostedboxer
May 25, 2015 10:05 AM
carid
Apr 30, 2015 07:00 AM
leon1
Apr 28, 2015 07:32 PM
GabberHead
Nov 20, 2001 07:32 PM
