Sponsored by:
Sponsored by: CARiD
Question on blacked out headlights
Old May 19, 2005
VP Stylee's Avatar
VP Stylee is an unknown quantity at this point
i'm not sure if this is the right spot to post this but here goes
i've been planning to blackout my headlights soon but i was wondering if i could use instead of the high temp paint flat black paint if i could use the duplicolor nighthawk black pearl pain?Also should i clear coat it after i paint it.
if any one has pictures of how the reflector comes off of an of 04 they would be greatly appreciated
Old May 19, 2005
FaiJai's Avatar
FaiJai is an unknown quantity at this point
should be posted in the lighting forum.
so far from what i've read for 04's you gotta sand down the chrome par and......prime it? coz the paint won't stick on properly if you don't. Do a search and you'll find more. good luck.
Old May 20, 2005
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
you don't have to use high temp. paint, but you can if you want to. It costs a few bucks more though. Before you paint, take some fine grit sandpaper and rough up the chrome a little bit, to give the paint something to stick to. Also, you can get a primer that is designed to adhere to plastic, which is what I used. That then normal gloss black spray paint, then a clear coat. The clear coat dulls the gloss a little bit, but clear coat is always a good idea. Since the headlight is enclosed, though, it should be OK without one.
Old May 21, 2005
sil04ver's Avatar
sil04ver is an unknown quantity at this point
It should look pretty cool, as long as you prime it and put a protectant clearcoat on. I wanna see someone colormatch their headlights....instead of using black, put red on a red civic, or blue on blue, etc....
Old May 21, 2005
VP Stylee's Avatar
my car is NHBP so it will be color matched
Old May 23, 2005
Peasey's Avatar
Peasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to beholdPeasey is a splendid one to behold
i sanded down the chrome and just used flat black primer paint..x 5 coats, no clear coat it looks good IMO
Old May 23, 2005
soonercivic's Avatar
soonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the rough
i used nhbp paint on my lights. Had it put in a aerosol can and then put some clear on it. looks good. you can really see the pearl in person. There is someone who did it in like a lime green for their lime green car. looks good.
Old May 24, 2005
Mr.Modify's Avatar
you don't have to sand it. I just primered it painted it and clear coated it and it came out perfect.
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
usajags84
15
Aug 19, 2015 03:12 AM
stryder12
Jun 30, 2015 08:33 PM
shaejb15
Apr 26, 2015 07:44 PM
