Sponsored by:
Sponsored by: CARiD
Tire Size Question
Old Jan 7, 2002
Stylee01's Avatar
Stylee01 is an unknown quantity at this point
Tire Size Question
I have a question about tire size. I am getting some 15" rims to replace the stock 14" hubs that came stock on the LX. My question is what tire size will return the car to original specs in order to keep the speedometer on target. I've heard all the following: 185/65/15, 195/65/15 and 205/60/15. I want the overall diameter to keep the speedo on, but I'd like to have a little wider series tire. Can anyone point me in the right direction? Thanks.
[IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Jan 7, 2002
CivicRacer5's Avatar
CivicRacer5 is an unknown quantity at this point
i have the same question????
Old Jan 7, 2002
Belle's Avatar
Belle is an unknown quantity at this point
with the tire calculator at top i figured the closest you can get is 195/60/15 the speedometer is .0650829... % too slow, so you probably wouldn't have to adjust the speedometer unless you were doing a hundred mph. but even then it would only be off by 6.5 mph. if you really want it to be exact you should take it to the dealership.
Old Jan 7, 2002
Would a 195/50/15 work on a 15x6.5????? What do the three numbers mean ?/?/?
Old Jan 7, 2002
antidote11's Avatar
antidote11 is an unknown quantity at this point
The stock size would be 186/65-15. Since you're replacing the 14", then I think the 195/65 would be closets to stcok.
But instead, get some 15" rims with 205/50-15"s....that's what they call a "street setup".
Old Jan 7, 2002
antidote11's Avatar
Yes those will work, you could even go up to a 215/50-15"....the three numbers are the (205) width of tire.....(50) height of sidewall...and of coarse (15) for 15" rims....and i think they are all based on millimeters. So a 205/50/15 is a tire that is 205 mm wide, a 50 mm high sidewall, for a 15" rim. Hope that helps and doesn't confuse : )
Old Jan 7, 2002
thanks alot antidote!!!!
Old Jan 7, 2002
antidote11's Avatar
Hey man...no problemo !!
Old Jan 7, 2002
LOWBOY's Avatar
LOWBOY is an unknown quantity at this point
I could see this if there were a $$$ problem, but why would you just go with 15" over 14"'s anyways? Why would you not want a set of 17"s with a lower profile tire?
Old Jan 7, 2002
Blv's Avatar
Blv
Blv is an unknown quantity at this point
<< ...and i think they are all based on millimeters. So a 205/50/15 is a tire that is 205 mm wide, a 50 mm high sidewall, for a 15" rim. >>
the numbers are actually not all in millimeters
205/50/15 means 205 mm width, 50% of the width is the height, so the second number is actually a percentage of the width
Old Jan 7, 2002
Belle's Avatar
did none of you read my first post... the tire calculator on the site figures all the difficult stuff for you. the only way you could do it without a speedometer adjustment is going with 195/60/15 and even that is off by .065%
remember, the lx stock tire is a 185/70/14 unlike the ex 185/65/15. even if you were to just put the ex wheels on your speedometer would be off.
here's my calculation
Old Jan 8, 2002
0100010's Avatar
0100010 is an unknown quantity at this point
<< the speedometer is .0650829... % too slow... ...you were doing a hundred mph. but even then it would only be off by 6.5 mph >>
Ummm, .065% would only be about a half mile an hour difference @ 100mph.
Old Jan 8, 2002
Stylee01's Avatar
<< I could see this if there were a $$$ problem, but why would you just go with 15" over 14"'s anyways? Why would you not want a set of 17"s with a lower profile tire? >>
...well $$$ is a factor. This is my GF's car, not mine. So she's the one making the decisions here. She found a nice looking set of American Racing 15's for dirt cheap. Otherwise, I would encourage her to go with the 17's myself.
Old Jan 8, 2002
how do you recalculate your speedometer and is it expensive????
Old Jan 8, 2002
Stylee01's Avatar
Well I guess I'll start the hunt for some good 205/50/15 tires this week...
Old Jan 8, 2002
Stylee01's Avatar
Well, I found some Kuhmo ECSTA Supra 712's for a good price on Tirerack.com. Any comments on these tires?
Link to tires
Old Jan 9, 2002
Stylee01's Avatar
No one has an opinion on the Kuhmos?
Old Jan 9, 2002
Stylee01's Avatar
Nevermind...just remembered the search feature. Found plenty of info [IMG]i/expressions/face-icon-small-blush.gif[/IMG]
MN-02-CivicEx
Jun 25, 2015 08:32 PM
bo_red
Apr 23, 2015 10:09 PM
NightKids2
Dec 8, 2001 05:50 AM
supercivic01
South
Nov 30, 2001 11:27 AM
