Grounding Kit or Hyper Voltage System?
Originally Posted by someguy
Ok, any one out there with either of these types of kits. Both claim to make the same thing happen to your car. Increased throttle response, brighter headlights, less radio noise, sometimes more power and better fuel enconomy. What I want to know is, is any of that true. Mainly the fuel economy. Looking up something for a friend. Dont need to know how to make my own...or someone to tell me its a waste of money. If it saves you gas...he wants it.
YOU ARE WASTING YOUR MONEY. THESE DONT DO **** AND WILL MAKE THINGS A LOT HOTTER UNDER YOUR HOOD. I KNOW OF A KID WHOS OIL CAP MELTED PARTLY BECAUSE OF THIS WASTE OF A MOD !!!
Keep telling yourself that. I thought it wasn't helping so took it off, noticed a drop in performance and put it right back on. Makes things alot hotter? How in the world do you figure that? The box itself is cool to touch, and the wires don't heat up either. Sounds like your friend messed up something.
i was talking about the wires.....there is a big debate on ephatch about these. they are worthless.
it would make sense if ur talking about grounding wires (not sure if its possible tho) but how could the hvs heat things up? all it does it connect to pos and neg of the battery, if anything it'd make the battery heat up, its not connected to anything else.
Okay then did you know that ground wires come stock from the factory or your car won't even work? All the kit does is upgrade them to larger gauge to improve electrical flow. They don't get hot at all. Now if you use 0 gauge, then there's gonna be problems.
CarStuff
Dec 6, 2020 12:52 PM
