Sponsored by:
Sponsored by: CARiD
Grounding Kit or Hyper Voltage System?
Old Jan 24, 2005
someguy's Avatar
someguy is an unknown quantity at this point
Ok, any one out there with either of these types of kits. Both claim to make the same thing happen to your car. Increased throttle response, brighter headlights, less radio noise, sometimes more power and better fuel enconomy. What I want to know is, is any of that true. Mainly the fuel economy. Looking up something for a friend. Dont need to know how to make my own...or someone to tell me its a waste of money. If it saves you gas...he wants it.
Old Jan 24, 2005
wonderz's Avatar
wonderz is on a distinguished road
i think you can install both kits together. I think these kits are more for people with a sound system in help with their light dimming problem and better throttle response in general. don't bet on it for having a better fuel economy, but it might help a bit, just don't depend on it.
Old Jan 24, 2005
Dishwasher's Avatar
Supertastic Member.
Dishwasher is an unknown quantity at this point
gearbox wrote up a review of it and said both were well worth it. I don't have one but it's high on my list of priorities.
Old Jan 24, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
i paid 20$ it was well worth it. I just wish I had gotten a different color because yellow isnt all that great.
Old Jan 24, 2005
The HVS is expensive but yes it does do almost everything they claim. Gas mpg up 2, noticable throttle response from a stop, smoother revs, works better with upgraded factory ground wires. Highly recommended. It's not a huge mod, but you'll feel a difference.
Old Jan 25, 2005
zachgeyer's Avatar
Grounding Kit my car woow
Old Jan 25, 2005
someguy's Avatar
thanks gearbox
Old Jan 25, 2005
PunkingCivic's Avatar
I need TP for my bunghole
check on ebay you can get this for around $60
or they have the new Sun Hyper Voltage System GT out now:
it come in all these colors: Black, Blue, Gold, Red, Silver
Old Jan 25, 2005
Ya other companies are starting to copy those things and integrate the ground wires into them. Apexi and a couple others. I would still get the original from Japan with your own ground wires. I got my hvs from optauto.com and you gotta search.
Old Jan 26, 2005
phydo's Avatar
phydo is an unknown quantity at this point
So is the HVS and the Ground kit the same thing?
Old Jan 26, 2005
hvs is an actual capacitor box that regulates the flow of voltage. Ground kit is just some wires that you replace the stock thin ones with.
Old Jan 26, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
so what .... these are factory replacements? ... or additions?
Old Jan 26, 2005
quick silver's Avatar
472rwhp @ 7400 RPMs and 12.93 psi
quick silver has disabled reputation
I will be doing a complete HVS kit on my car. I think the cost of the kit itself is around $200.
Old Jan 26, 2005
With the ground wires, I chose to just replace the factory grounds rather than run wires all over the place that don't help anyway. The hvs just connects to the battery terminals. It helps more with the ground wires, but not necessary. The hvs does give a noticable difference.
Old Jan 26, 2005
Seems like you are defeating the purpose of the kit seeing as how they made special ground wires which go to 4-5 different places in the engine bay.
Old Jan 26, 2005
Well no, each factory ground is tied back to the battery, just like other kits. The only difference is I'm only grounding factory determined points and not 5 different places on the chassis that do nothing.
Stock grounds are tranny, chassis, and engine (thermostat housing). That's all you need and it's actually bad to ground everything in sight (ground loops = bad things happening).
Old Jan 26, 2005
Well, if that is what you say. I am no expert, but I am sure that the company designed the kit such that all ground wires are actually hooked up.
BTW, what guage wire are you runnin from ya battery to the chassis?
Old Jan 26, 2005
And I'm sure honda chose their ground points for a reason. It's all 4 gauge wire. I'm running a larger terminal with the chassis ground connected to the terminal itself, and the engine and tranny grounds with ring terminals on the screw. I shaved the ground areas to get a better connection, however they are getting rusty even with dielectric grease. I need to sand em down when it gets warm again.
Old Jan 27, 2005
kornsined's Avatar
gearbox can you post some pics of the 3 major ground points?
Old Jan 27, 2005
czechcivic's Avatar
czechcivic is an unknown quantity at this point
Ive been wanting the mr system....But I wanna buy it used......I havnt even seen one used yet
Old Jan 27, 2005
because everyone likes it so much
I'll try and take a few pics, but they're easy to find. Just follow the wire from the negative terminal to a bracket mounted on the chassis, follow it more to the tranny. The other one is that wire going from the engine block to the front frame in the middle. So just remove all those cables and put three new ones to the battery negative and run one to each stock grounding point.
Old Jan 27, 2005
realitycheck's Avatar
realitycheck is an unknown quantity at this point
Did you just use 4 gauge speaker wire, or did you buy electrical wire, and do you know how many feet you used?
Old Jan 27, 2005
kornsined's Avatar
what about the alternator is that one neccessary?
Old Jan 27, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
mr system?
Old Jan 27, 2005
davidoff1's Avatar
davidoff1 is an unknown quantity at this point
I've got both HVS and HGS, they did help a little..... like wat gearbox said...
Old Jan 27, 2005
MishBallzEM2's Avatar
I'm The Ballz Of 7th Gen
MishBallzEM2 is an unknown quantity at this point
if you go onto Ebay and look for "Hardcore Tuning" he is selling some decent ground kits....Thats my boy from MA..he'll hook you up with some good prices
Old Jan 27, 2005
kornsined's Avatar
so is there any difference between a cheap one and a more expensive one?
Old Jan 27, 2005
I bought mine for $40 basically some wires with ring terminals put on already. Homemade, but really it's all the same stuff. Just make sure it's quality 99.9% copper. I would not go anything thicker than 4 gauge either.
Old Jan 27, 2005
kornsined's Avatar
i meant the HVS that you see on ebay.
Old Jan 27, 2005
oh um the real one that says hyper voltage system is the one from Japan. The others are knockoffs and might not have the same quality. But I think apexi is a good company for the most part. Theirs may be better than most.
