Sponsored by:
Sponsored by: CARiD
how to black out headlights?
Old Jan 22, 2005
civic_luvr's Avatar
civic_luvr is an unknown quantity at this point
How do u black out oem headlights? dont wont to spend $$$ on aftermarket.
Old Jan 22, 2005
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
use the DIY for clearing headlights in the DIY section and while u have the headlight apart, paint the chrome trim piece black.. also Search the forums for Black out headlights... many people have posted up their DIYs.. good luck!
Old Jan 22, 2005
ACURAwerx's Avatar
ACURAwerx is on a distinguished road
yea its easy.. good luck!
Old Jan 22, 2005
2k3kansasEX's Avatar
Got the broccoli in my back pocket
2k3kansasEX is an unknown quantity at this point
Old Jan 22, 2005
boombazokajoe91's Avatar
I survived that B*tch Katrina !!!
boombazokajoe91 is an unknown quantity at this point
i hear its really easy.....i know they have diy on it.
Old Jan 22, 2005
se7engen_riDe's Avatar
se7engen_riDe is an unknown quantity at this point
i never really say this to people but please search. you will find a whole buncha topics that are posted about blacking out your headlight housings.
Old Jan 22, 2005
I just did some for fun.
1. bake lights in oven 250F
2. pull apart, remove chrome insert.
3. mask off the singal and parking lights
4. prep with fine sandpaper
5. spray with primer
6. spray with hi temp flat black ceramic paint
7. put back together
8. stick in oven, press the halves together
Old Jan 22, 2005
SOHC's Avatar
I spent 1425 points to do this.
SOHC is an unknown quantity at this point
"Really easy"!? I dont think so! It can be a real pain in the ***. If you arent careful enough (sometimes you cant help but screw up), the black sticky stuff that holds the headlights together will make a mess and ruin your light housing. also- dont even think about cleaning it off of the silver plastic inside the housing- the silver will come right off like it was dust!
On top of that- you have to deal with fogging issues. which (like many have experienced) will force you to open your headlights back up and put some more goop in there, or hot glue gun it like i did!
Go for it, its a good experience, but in the long run- unless youre some sort of DIY god, youre better off spending the $100 or so on ones that are already done for you.
Old Jan 22, 2005
SOHC's Avatar
ah yes. the silver paint problem wont apply to you. instead u have to worry about getting a nice even coat of paint on it
Old Jan 22, 2005
This was one of my first mods, when I didn't know anything. Cleared my own lights, no problem, did another set, and another (coupe and sedan) then the black ones. It's super easy and I've never had the goo run off. It stayed in those channels and we sealed em up using the same goo.
Old Jan 22, 2005
ncirom2003's Avatar
i took apart my aftermarkets to paint inside same color as car... its fairly easy if you have patience and knowledge... when peeling peices apart be careful and take your time dont be too forceful. also even after you rebake them to put them back together id buy a little bit of sealent frome home depot and just poor a thin beed into the headlight b4 joining them... mine get water in them like i pay them to .. because i didnt heat it up b4 joining
Old Jan 22, 2005
maiden4ever's Avatar
maiden4ever is an unknown quantity at this point
i didnt even bake mine, they just pulled apart...it was gooey. when i was done i just pushed em back together really hard with some of those quick grip clamps, put the little black clips on and i havent had an leak problems
Old Jan 22, 2005
ncirom2003's Avatar
lucky ***** ^
jk
Old Jan 22, 2005
ya the coupes were alot easier to do.
Old Jan 23, 2005
kornsined's Avatar
Originally Posted by 2k3kansasEX
buwhahahaha your sig is funny.........must add to my sig...
Old Jan 23, 2005
zachgeyer's Avatar
look
Old Jan 23, 2005
Mr.Modify's Avatar
im surprised this hasn't been locked..
wingsfan19
Oct 1, 2015 03:45 AM
MamaBear2015
49
Sep 29, 2015 01:12 PM
MamaBear2015
Sep 4, 2015 09:04 PM
jpat21
Sep 3, 2015 11:32 PM
mac25
Aug 21, 2015 11:14 PM
