Sponsored by:
Sponsored by: CARiD
Cryogenic Intake System
Old Jan 22, 2005
isuzu5000's Avatar
isuzu5000 will become famous soon enoughisuzu5000 will become famous soon enough
Holy crap...look at this. It can produce 5-6 psi. No header connection needed. Its supposed to "clean" up your engine bay by not having as much stuff. What do you think the pros/cons of this thing is?
Old Jan 22, 2005
02boostlessCIV's Avatar
Addicted To Boost
02boostlessCIV has a spectacular aura about02boostlessCIV has a spectacular aura about
remember gas runs out, real boost doesn't, unless your turbo is messed up
Old Jan 22, 2005
isuzu5000's Avatar
Yeah i know....oh yeah its called the Cry0-2 System by the way. It was said to be one of the "top items at sema"...but so were the l.e.d.'s for the purge lines.
Old Jan 22, 2005
Mischieflts's Avatar
Mischieflts is an unknown quantity at this point
don't turbos generally reduce the lifespan of the engine? i would much rather have the option to shoot up power when i need it instead of having it constantly wearing stuff out.
Old Jan 22, 2005
Ohsosikcivic's Avatar
Ohsosikcivic is an unknown quantity at this point
get a WRX like me... then u dont have to worry about Cryo2
Old Jan 22, 2005
Addicted To Boost
yes however if he was running 5-6 psi with the turbo i dont think he would really wear it out. And plus you dont have to run full throttle all the time just when you need to.
Old Jan 22, 2005
jakejham's Avatar
jakejham should not be trustedjakejham should not be trusted
exactly, turbo can be just as safe as n/a if done correctly
Old Jan 22, 2005
isuzu5000's Avatar
very true...but i have yet to see this actually installed on anyones car. havn't heard too much about it other than it substancially cools air and fuel as they flow through your engine causing them to be denser, allowing more to pass through, therefore you get the bigger bang which in turn gives you more power. (Like I said I still don't know too much) I've heard these systems pumping out up to 50 RWHP on supercharged and turboed applications and up to 30ish RWHP on N/A applications. The system itself is pretty cheap and runs around $500 and is supposably %100 safe/detonation free.
Old Jan 22, 2005
skipbarber's Avatar
engines that were designed to be boosted last just as long as N/A cars..I know this first hand. Adding any kind of forced induction to any motor that isnt designed for it will reduce its life span.
Old Jan 22, 2005
Killacamshaft's Avatar
G'z UP
Killacamshaft has a little shameless behaviour in the past
Ive seen em around dont know too much
Old Jan 22, 2005
suthrninca's Avatar
suthrninca is an unknown quantity at this point
I believe your thinking about the intake cooler. This is a turbine powered by a cryo2 bottle. It's boost.
Old Jan 22, 2005
xX03EXx's Avatar
Sweetest Dude on 7th Gen
THe concept is cool I guess, but there is more to a boosted car than the turbo. You need more fuel for the increase in air and the correct tuning. All I can see that thing do is cause problems.
Old Jan 25, 2005
IronFist's Avatar
How much does it cost?
Old Jan 25, 2005
isuzu5000's Avatar
I'm just goin' by what the mag. said. It said that one of its major pros is that it clears up space in your engine bay. It's supposedly costs around $500.
Old Jan 25, 2005
Kohburn's Avatar
Kohburn is an unknown quantity at this point
looks like it'd work better than the electric superchargers.. but if you run a bottle why not just use nitrous oxide? you'd get more power out of the bottle that way. Only reason I can think of to use that setup is if its street legal (since nitrous isn't)
Old Jan 25, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
I saw this at DEI's booth at PRI. The idea is good, but personally I believe they need to do a little more R&D. The "turbo" itself, moves a great deal of air, but the whole fact that you will run out of CO2 will be a downside.
Old Jan 25, 2005
Changu-San's Avatar
Mr. Clean
wow...its about the same price of N2O
Misfit2613
Jul 30, 2015 09:49 AM
Dani1993
Jul 24, 2015 09:02 AM
hoofboy
Jul 17, 2015 04:27 PM
LorenzoC0395
Jul 14, 2015 08:46 PM
NoobyKid
Jul 13, 2015 07:53 AM
