Sponsored by:
Sponsored by: CARiD
Headlight ?
Old Dec 18, 2001
2k1civicman's Avatar
2k1civicman is an unknown quantity at this point
Headlight ?
Have a friend w/96 Accord and he has gona through so many headlight bulbs. He found out he needed a higher wattage fuse for them. Do I need a higher wattage fuse also or not. I have H4 in there now 100/80W
Old Dec 19, 2001
silvervtec01's Avatar
silvervtec01 is an unknown quantity at this point
you should be fine, but you might wanna wait until you actually start having problems with this before you go messin with it, cuz u might just cause more problems.
Old Dec 19, 2001
CoupeStylz's Avatar
Si(R) killer # 1
CoupeStylz is an unknown quantity at this point
Wouldn't it be a lower wattage fuse, so that it blows before the headlight?
Old Dec 19, 2001
maybe it is lower. Who knows I'll just wait till they burn out if they do. Thanx
Old Dec 19, 2001
Bartkat's Avatar
Depends on whether that wattage is inpur or output. You have a 15 amp fuse for each headlight. They probably will hold. The problem may show up later after the wires run too hot for too long.
If you are 60/55 watt input, then you are ok.
meicalnissyen
Sep 25, 2015 12:12 AM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
