Sponsored by:
Sponsored by: CARiD
engine oil
Old Dec 6, 2004
Pn0ybOiLiKehOy's Avatar
Pn0ybOiLiKehOy is on a distinguished road
engine oil
well, way overdue for an oil change...what do u guys reccomend i change it will...i live in california bay area if that helps. and im driving to LA soon so i wanna take the precautions before going. help please
Old Dec 6, 2004
wrussi's Avatar
wrussi is an unknown quantity at this point
dont try to be way over due for oil changes that much that shortens the life of the engine really fast!! plus it also afects performance
get sinthetic of u dont like to change ur oil that frequenly is worth the +5 dollars
if you dont have time like i do just buy the il and take it to the honda dealer is 8.99 the labor to change the oil also buy the honda filter
Old Dec 6, 2004
Michalo187's Avatar
Abortion Survivor
yeah you also loose fuel economy which we are best, yeah get synthetic so you dont worry
Old Dec 6, 2004
def01tones's Avatar
You bought a used dog??
def01tones will become famous soon enough
Change Ur Damn Oil!!
Old Dec 6, 2004
lol thanks alot guys hah, next question: should i just go to kragens/autozone or costco?
Old Dec 6, 2004
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
I would highly recommend Redline 5w20. If you don't want to be quite that spendy, Motorcraft 5w20 is extremely good for a mineral oil.
Old Dec 6, 2004
Flashlightboy's Avatar
Flashlightboy is an unknown quantity at this point
I agree with 4drcivic2k1. I currently use RL and have no complaints whatsoever. If you didn't want to spend the money or the funds aren't available I'd suggest using MC.
M1 would be my second choice behind RL if you could swing the cost. Otherwise, I'd go with MC. It's a very good oil.
But change it every 5k, OK? The Honda engine is durable but not immune to damage from abuse.
Old Dec 6, 2004
ill start changing it regularly...i heard every 3000 though? waht should i do?
Old Dec 6, 2004
3k is old school and it's what Iffy Lube wants you to believe. The truth is that today's oils are so much improved that 5k is a good interval. Consumer Reports found that 6k in New York cabs was a good interval although I'm suggesting 5k because it's easier to keep track of on the odometer.
If you were using a high quality syn you likely could go to 7.5k but to be safe, use a good quality oil and change it every 5k. Any sooner and you're just throwing good oil away.
Old Dec 7, 2004
I run redline and change every 10k. I do an oil analysis halfway through though.
Old Dec 7, 2004
realitycheck's Avatar
realitycheck is an unknown quantity at this point
Yeah I run mobil 5w-20 and every 10k no probs so far.
Old Dec 7, 2004
exturbo6's Avatar
10k...i change mine every 3-4k. i know its old school like flashlightboy said but 10k seems too high. even thou the manual for the car says i think 7k to change it. but i drive 45 miles to work jusy one way. so thats give or take 90 miles a day. when is it really the right time to change the oil?
Old Dec 7, 2004
joe6680's Avatar
joe6680 will become famous soon enoughjoe6680 will become famous soon enough
The manual suggests every 10K...
Old Dec 7, 2004
exturbo,
If your 90 miles is mostly freeway then you can comfortably and safely go to 7.5k. Freeway driving is the easiest kind on your engine and engine oil. The 5w-20 oils, especially the syns, are so well engineered that 7.5k of freeway driving wouldn't cause a problem. If you want to use a high quality blend then the MC 5w-20 will make it to 5k and protect your engine very well along the way. It's also cheaper than any syn if cost is a consideration.
The manual does suggest 10k but it also suggests to use only Honda fluids, Honda wipers, Honda parts, Honda oil and so on. Choosing the right interval is based on your driving and how hard you stress the motor.
Bottom line - Extend your interval to 5k regardless of the oil. Your wallet will be happier and you won't be doing any harm to your engine.
Old Dec 7, 2004
exturbo6's Avatar
thanks man.
yeah im driving all highway.but the thing is when its comes to my car i would rather spend the money on a oil change since i am putting alot of miles oin my car. its seems like i burn alot of oil.in the summer i checked my oil when it was close to the oil change and i was low on oil. so i mean idk if its the weather, but i fell comfortable doing that just so i know im not going to blow the car up. but i do understand its a lil more money to be doing that every 3 to 4k, but now i have a turbo setup, so i wanna take as muich care of this car then i have ever..and i wash and check everything atleast once a week.does synthic oil last longer?or better for a turbo car?
Old Dec 7, 2004
X,
I didn't know you had a turbo because that, IMO, changes things drastically. If you're constantly running boost 5w-20 is going to get beat to death and I'm not surprised that you have consumption problems.
The turbo puts in your engine in another class similar to a DOHC VTEC and you need a thicker oil. I'd suggest that you run German Castrol 0w-30 (Autozone) or even the M1 0w40. These oils are approved for the VW 1.8L turbo and meet long term wear and cleanliness standards.
These are good syn oils that your engine will benefit from especially since you have a turbo. I'm not surprised that your engine is burning oil because 5w-20 wasn't designed for turbo use. You might want to try M1 Racing oil which is a but harder to find or you can give some consideration to the M1 Truck and SUV. Don't be afraid of the name because what's in the bottle is good for you engine.
Old Dec 8, 2004
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
walmart, mobil 1 5w-30 fully synthenic. 5 quarts for $19... cant go wrong with that.
ask anyone about mobil 1 motor oil... very good **** my friend
Old Dec 8, 2004
exturbo6's Avatar
yeah im running a turbo. sorry i didnt say earlier. but mobil 1 ill look into. the synthenic blend. im not sure what oil is in my car now. the shop put it in when they installed my kit. so from now on ill just get the mobil 1 oil.
good looks
MyCivic
Electrical
Oct 28, 2021 11:06 PM
BootyDo
May 7, 2015 04:46 PM
SoNiCcIvIc
Mar 11, 2002 03:37 PM
Grey
16
Jan 27, 2002 11:34 PM
civiccowboy
Nov 19, 2001 03:44 PM
