Sponsored by:
Sponsored by: CARiD
shifter knob threads
Old Aug 17, 2004
Shifter's Avatar
Shifter is an unknown quantity at this point
shifter **** threads
Does anyone know the pitch of the OEM shifter **** threads? I believe they are 10 mm, but I don't know the pitch - maybe 1.25mm? Also, does anyone know if the threads for a 2001 civic are the same as those in a 2000?
Thanks.
Old Aug 17, 2004
zen_master's Avatar
u might want to do the search =)
it's a universal size in nearly all generations of civic..
i forgot though........some other member definitely know about it..
Old Aug 17, 2004
518's Avatar
518
518 is on a distinguished road
I am using the same shiftknob with the same adapter from my 1996 GS-R to my 2004 Civic. This should give you an idea that they could be the same.
Old Aug 17, 2004
bobbyd's Avatar
bobbyd is an unknown quantity at this point
They are the same as the S2000 10 X 1.50 mm
Old Aug 17, 2004
Shifter's Avatar
new shift **** design
Thanks alot, everyone. I'm in the process of making a translucent shift **** for my niece and since my **** design is much shorter than the stock unit, I may include a polished aluminum hex-spacer to cover the bare unthreaded shaft. If anyone would like to see what it looks like, check out this post in the Corvetteforum:
http://forums.corvetteforum.com/showthread.php?t=883988
Dave
Old Aug 18, 2004
bobbyd's Avatar
Looks great man! You do sweet work!
Old Aug 18, 2004
Shifter's Avatar
Thanks! Some near-future variations will include a 2.5-inch diameter ball **** (for large hands) and a larger Hurst-style ****. One guy at work has given me a small flag to embed in the resin. It should look unique in his Datsun Z.
Dave
Old Aug 18, 2004
bobbyd's Avatar
Dave
Yeah, I am a bigger fan of the ball type shift *****. I use VooDoo shift ***** and love the feel. Show some pics when you get the Datsun done!
Old Aug 18, 2004
Shifter's Avatar
Bob,
What's the diameter of the VooDoo ****? Do you have any calipers so you can measure it? I know that the Hurst ball-***** are 2 and 1/4 inches in diameter, but I've heard that some manufacturer's ***** are only 2-inch.
Old Aug 19, 2004
bobbyd's Avatar
Bob,
Here are some links below. I have the S2000 **** with comes in a 1.8xxx sphere or a 2" sphere. I believe I bought the 2".
http://www.teamvoodoo.com/Voodoo/*****.html
http://www.teamvoodoo.com/Voodoo/Applications.html
Old Aug 19, 2004
Shifter's Avatar
...great info - THANKS!
Old Aug 19, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
i want one too!!! but i dunno what color!!! the red one looks HOT.. but so does the blue
Old Aug 19, 2004
Shifter's Avatar
I can make red, blue, yellow, green, orange, purple, and any shade of these colors (although light-red ends-up looking pink). My plan is to install a few in coworkers Hondas for "Field Testing". If I get the thumbs-up, I'll post something in this forum.
Bob, I didn't realize it at first, but that second link contains a pretty good list of vehicles and their shift **** thread sizes. That'll save me alot of research time - thanks again!
Old Aug 19, 2004
civicvtec1ps's Avatar
Search and Learn
If you are planing to sell shift *****, Make sure you pay for 7thgen vendor fees.
Old Aug 19, 2004
abmerop18's Avatar
Jam out with your clam out.
that would be cool if you could get one silverish in color
Old Aug 19, 2004
Shifter's Avatar
I will definitely look into it!
That is possible if I add some metallic powder to the mix. Gold and silver flakes are available; I just need to buy some to see how the combo looks - good suggestion!
Old Aug 19, 2004
civic01vtec's Avatar
now that is some good ****
Old Aug 19, 2004
xam's Avatar
xam
snooty patooty partier
xam has a spectacular aura aboutxam has a spectacular aura aboutxam has a spectacular aura about
i got the gunmetal skunk2 shift ****, and i love it. the nut on the bottom really holds the spacer nicely, but i cant get it to go really low
Old Aug 20, 2004
Shifter's Avatar
I saw a similar **** on a coworker's Civic a while ago and his **** had a nut underneath, too. I'm trying to get away from having to have a hexagonal locking device, primarily because it tends to take away from the looks. Picture a mirror-polished cylinder that is about 1.5-inches long under the ****. You can grab it with Channellock pliers and a strip of rubber (to protect the aluminum finish) when you lock it to the shift ****. I may also throw in some removable Loctite threadlocking liquid as an extra precaution.
Old Aug 20, 2004
WannaBFast's Avatar
hey.. is would it be too much to ask for a metal shaft down the middle to hide the threads?
Old Aug 20, 2004
Shifter's Avatar
I'm going to try this with hexagonal aluminum. However, there are some process difficulties to overcome. Let's say that I extend the hex rod from inside the **** and down to the shifter boot. The hex rod shape is great to prevent the **** from spinning on the rod, but if you normally hold the shifter so that some of your hand is below the bottom of the shift ****, the hex-shape may not feel comfortable.
Now if I just encapsulate a small length of hex rod and then use a round rod to lock up against the bottom of the shifter and extend down to the boot, the hex rod would have to be positioned exactly in the center of the bottom part of the ****. Otherwise, the round locking shaft would not be centered and would look pretty bad, once assembled.
It's alot easier to machine a threaded hole in the **** after the plastic **** has cured. When it is still liquid, positioning the hex rod on-center is tough because the mold is made of soft silicone.
Still, I'll give it a try and see how it turns out - good suggestion!
Dave
Old Aug 21, 2004
SimplySLB's Avatar
Ms. Moderator
SimplySLB is a name known to allSimplySLB is a name known to allSimplySLB is a name known to allSimplySLB is a name known to allSimplySLB is a name known to allSimplySLB is a name known to allSimplySLB is a name known to allSimplySLB is a name known to allSimplySLB is a name known to all
wow, very impressive. I would totally like a purple one. Something differen.t Definitely keep us updated!
Old Aug 22, 2004
Shifter's Avatar
Thanks! I'll be pouring some more colors soon (and since two people have requested purple so far, one of the show-***** will be purple) and will drill and tap them to present a realistic image. An advantage that a Honda **** will have over one for a Corvette is that I will not have to thread the Honda's in as far. Therefore, more translucency will be visable.
Old Aug 23, 2004
bobbyd's Avatar
No problem! I figured that would help.
GolNat
Nov 27, 2018 03:32 PM
velozp
Dec 13, 2015 11:28 AM
Jrosa
Sep 14, 2015 08:24 PM
Civic720
Sep 10, 2015 10:06 AM
junkyardguy
Sep 2, 2015 06:07 PM
