Sponsored by:
Sponsored by: CARiD
V-afc 2
Old Jul 13, 2004
gtracing's Avatar
TeLLy is my daddy
gtracing is an unknown quantity at this point
V-afc 2
ok, first off, I've read and re-read every single V-AFC2 thread there is on 7thgen....
secondly, i've checked all my wiring, i've soldered all my wiring, i connected the vtm wire and there are no diodes....
here is my question, how did you guys get vtec to work? how did you set it up? i got my car dynoed today and i got about 5whp gain from just the a/f tune, we tried to change the vtec engagement point to 4000rpm and after couple of minutes the CEL came on....
HELP!!!!!!!
Old Jul 13, 2004
The vtm wire being connected should solve this. Here's a hint--changing the vtec point will almost always cause you to lose power anyway.
Old Jul 13, 2004
gtracing's Avatar
TeLLy is my daddy
the vtm wire is connected like stated above....
and yes, changing the vtec point does infact make you lose hp, but we found that at 4000rpm, ur car doesn't lose hp...well mine doesn't...
Old Jul 13, 2004
Can you post your tuning results and curves, along with mods?
Old Jul 13, 2004
gtracing's Avatar
TeLLy is my daddy
right now i have:
ground kit
aem v2
4-1 race header
v-afc2...that's about it (that i can think of that adds power)
everything else is suspension
but i'll have to go write down those numbers and i'm not home right now, so i'll try to get that done tonight....the weird thing is that i tried setting the vtec to kick in at 4000rpm and 3800 rpm, and it still gives me the CEL....
keep in mind i own a 2003 Acura 1.7EL, d17a2 engine in a sedan chassis
Old Jul 13, 2004
Oh now I see. Thanks if you can post those fuel numbers. I tried to tune mine just a little, but I have no way to know exactly. I have a ported cylinder head with header and that's about it. So our setups may be similar.
Your car may have a different pre-setup adjustment. You did set the pre-operation options before you started the car I hope. Stuff like throttle position, vtec type, sensor input,... if you didn't you may have caused engine damage. I know for our civics, the vtec code is =3. Don't know what engine you have. Maybe the same as a regular civic?
Old Jul 13, 2004
gtracing's Avatar
TeLLy is my daddy
same engine as the civic ex u guys have
d17a2 engine, 127hp
Old Jul 13, 2004
02CivicRider's Avatar
02CivicRider is an unknown quantity at this point
so all the things that i keep hearing arent true the V-AFC2 does work in our civics. ive heard a lot of rumors about them not working right in our car.
Old Jul 13, 2004
I have the vafcII in my EX and it works perfectly. No engine light, and I have the fuel turned up a little. Others also have it working, so I don't know what's wrong. Did you do the initial setup when you first installed it?
Old Jul 14, 2004
gtracing's Avatar
TeLLy is my daddy
yes i did the initial setup...everything is set correctly..so i really don't know...
but yea, i haven't gotten time to deal with the writing down number part...but to let you know, our cars run rich at low rpm's and lean at high rpm's...so u might wanna reverse some numbers around if u cranked it all up
Old Jul 14, 2004
I'll post up what I did later. But I figured it would run like that. I just have around +2 for wide throttle, but that's just guessing.
Old Jul 14, 2004
gtracing's Avatar
TeLLy is my daddy
don't guess, get it done right...because it's very sensitive...just up or down 1 point can change your entire a/f curve....well straight line in my case...
Old Jul 14, 2004
ImportRacer2123's Avatar
K20 Member
Im Running a VAFC II and it works just fine... NO CEL Nothing... VTEC kicks in at 4400RPM
Old Jul 14, 2004
Well I'm wondering if I should turn it off til I get tuning, but I don't want my car to be running lean.
Old Jul 14, 2004
Well I turned it off, and acceleration at high rpms feels the same, if not better. I'm just gonna leave it off for now then.
Old Jul 14, 2004
aznstylez254's Avatar
Jspek Inspired
aznstylez254 is an unknown quantity at this point
ours cars actually run rich as hell in stock form.
Old Jul 14, 2004
Is that overall? Like both high and low rpms? Maybe Honda was doing it just to be sure there is no lean problems. My car feels good with the ported head, and gas mileage went way up to 38mpg. I could tell from my old plugs about the rich thing, because they were all black. I really need to find a dyno. It may be that the ported head cancelled out the richness and now it's running fine.
Old Jul 14, 2004
gtracing's Avatar
TeLLy is my daddy
yes, our cars run rich at low->high rpm's....so u might wanna turn down everything or leave it stock..or else ur just wasting gas
Old Jul 15, 2004
So what did you end up tuning then? I really need to get mine on a dyno.
Old Jul 15, 2004
gtracing's Avatar
TeLLy is my daddy
well basically i tuned the a/f...and i tried to get the vtec working but couldn't so just left it...
i borrowed my friend's obd2 reader/eraser thingy today, and i tried to set the vtec, i got it to work but after a few blocks the cel will come on...then i would simply delete the code right? wrong, the cel keeps on coming on....so i guess i have to leave it...
MAPernoud
98
May 18, 2005 10:53 PM
xgodxicex
Jun 11, 2004 03:42 PM
ImportRacer2123
Sep 14, 2003 02:46 PM
5PEED EX
Jun 10, 2003 04:28 PM
somean2
Apr 5, 2003 09:56 PM
