Sponsored by:
Sponsored by: CARiD
Water in Altezza's
Old Nov 12, 2001
godka0s's Avatar
godka0s is an unknown quantity at this point
Water in Altezza's
For those people that have the APC altezza's (preferably CF), have you guys got water into them?... Just yesterday, I was washing my car, and I got water in them.. luckily, it wasn't where the lightbulbs where but the outer layer.. from what i heard, it's a manufacturing defect that some APC's altezzas have... Please let me know what the scoop is.. thanks
Old Nov 12, 2001
kristy's Avatar
kristy is an unknown quantity at this point
yes you can do a search on this and you'll have more answers than you need...i have cf apc altezzas and yes, they do leak. like I said, try the search, you can seal em up or do whatever...hope this helps
Old Nov 12, 2001
cwick187's Avatar
cwick187 is an unknown quantity at this point
yeah, i had the same problem. Just seal around the edges with silicon, and then put them back in. If you don't decide to return them. APC sucks as far as quality parts!!
Old Nov 12, 2001
antidote11's Avatar
antidote11 is an unknown quantity at this point
I haven't had one single problem with my APCs, but then again, I had them professionally installed.
Want my opinion, here it goes.......Pay someone to install them, that way if they leak, they will be replaced and/or fixed !!
Old Nov 12, 2001
Bartkat's Avatar
Some of the older ones leaked. Some also didn't met SAE/DOT specs on account of no side reflectors.
I put in APC carbon fibers and have been trough the high pressure car wash several times and in some hard rains and not one leak.
Old Nov 12, 2001
cwick187's Avatar
I don't think that having them installed by a shop has anything to do with them leaking or not, because it only took me 15min to install mine(very easy) and if you want to spend money having them installed by someone when you could just DIY, then whatever . But I understand what antidote said: "If you have them installed by a shop, just take it back and they will more than likely fix it". As far as other people not having problems with them, I guess it all depends if you get lucky when purchasing the lights wether or not they leak.
Old Nov 12, 2001
WeSSoN's Avatar
WeSSoN is an unknown quantity at this point
Just let them dry and then silicone them up......all the "shop install" could have done is if they had siliconed them for you....but just do it now.
Old Nov 12, 2001
WeSSoN's Avatar
Old Nov 12, 2001
antidote11's Avatar
It took them almost over an hour to install these lights in my car......I watched them do a little bit, and they were bending clips around some of the edges and siliconing the clips to the light, then the light to the car.......So I'm pretty sure I couldn't have done them myself.....they are after market, so they won't fit perfectly....and me knowing that, had it professionally done. It cost me 25 dollars to have them installed....I couldn't pass it up.
Old Nov 12, 2001
MY01HX's Avatar
MY01HX is an unknown quantity at this point
Well it took me 20 mins to do mine, a hour seems kinda unreal. Anyway, APC sold good ones and bad ones! You must have got a good set. Mine leak, like a sum bit*h! But I plan on sealing them myself. I done with dealing with APC, they suck![IMG]i/expressions/face-icon-small-disgusted.gif[/IMG]
Old Nov 12, 2001
CivicVTec's Avatar
CivicVTec is an unknown quantity at this point
let them dry it first then seal it well with sillicone
solarpunk70
Apr 12, 2016 11:43 AM
Munzy
21
Oct 7, 2015 07:48 AM
Bruce2
Sep 27, 2015 08:45 PM
Sep 27, 2015 11:33 AM
speedlever
Sep 24, 2015 07:18 PM
