DIY reverse el gauges???
Old 11-09-2001
meels808's Avatar
meels808 is an unknown quantity at this point
allright, i am determined to get these reverse el gauges installed, but i dont even know where to start, i cant get the dash off i am not sure how, or if it even has to come off someone please helP!!!
Old 11-09-2001
IDQcivic's Avatar
IDQcivic should not be trusted
It's pretty easy to do. First look for 2 screws upside down on the top part of the frame around the old gauges, and unscrew them. THen put a flathead on the bottom part and pry it out, be careful not to scratch anything. THen just unscrew the gauge cluster and remove it to a comfortable working space. Then just unclip the plastic piece, install the new gauges, then put everything back together. Look on the stock wire harness on the left there should be a black and red wire, that's where you need to get power to they turn on with your headlights. It's really an easy job. The hardest part is getting the indiglos OVER the needle, just keep trying!
Old 11-09-2001
meels808's Avatar
thanks! you have really helped me out a lot, i wasnt sure if i had to take the whole dash off, i am glad that i dont have to, so the red and black wire is where i get power from, where do i put the black batttery that comes with the gauges?
bolt-on-bandito
Electrical
32
01-15-2020 03:25 PM
ThatGuy913
09-28-2015 05:35 PM
ktae13
Electrical
09-26-2015 05:14 PM
260000milesgoal
09-25-2015 07:41 PM
speedlever
09-24-2015 07:18 PM
Quick Reply: DIY reverse el gauges???
