Sponsored by:
Sponsored by: CARiD
New e-mgt computer
Old Feb 22, 2004
halocivic's Avatar
halocivic is an unknown quantity at this point
New e-mgt computer
I just looking for some new mods for the vic, and found this computer. I was wondering if anyone knew anything about it. I am also intrested in your thought........buy or not to buy?
http://www.nextlevelracing.com/Triphase.htm
This is what the web page has to say:
The Tri-Phase module enhances performance in multiple ways. First, it modifies signals being read by the ECU, causing an adjustment to the fuel curve, which is what creates the increase in horsepower and torque, as well as improves throttle response and shift speed. A second feature of the Tri-Phase is it's "High-Heat Signal Correction." In short, when the engine compartment heats up, some sensors that relay pertinent fuel curve contingent information to the ECU begin to lose accuracy due to heat absorption into the sensor. The ECU then reads these incorrect signals, and leans out the fuel curve, which is bad for performance. These errors cannot be corrected from within the computer, there must be an independant unit to correct these errors. The Tri-Phase module is designed to automatically compensate for these signal errors. The Tri-Phase performance module is a simple installation to your vehicle's intake air temperature sensor, maf/iat combo sensor, air flow meter or map wiring harness(see applications chart, vehicles must be fuel injected). Our easy to follow, step-by-step instructions will allow you to get your module installed in about 15 minutes, even if you don't have any mechanical experience.
Tri-Phase vs. Stage 1 G-Box Comparison
The key difference between the G-Box and Tri-Phase modules is versatility. The "+" setting on the Tri-Phase module is roughly equal to that of the Stage 1 G-Box. The "++" setting on the Tri-Phase module is the more aggressive, race oriented setting, which may require premium fuel for use, but provides superior gains in horsepower and torque. The Tri-Phase module may also be turned on and off, which is very beneficial to users who are required to have emissions tests done during inspection. Both modules are a terrific "bang for the buck" and one is not necessarily better than the other, it really depends on what you are trying to accomplish.
Tri-Phase Hp & Torque Statistics
Result
Average Horsepower Gain Range
9 - 15 Hp
Average Torque Gain Range
7 - 10 lb/ft
Median Horsepower Gain
11 Hp
Median Torque Gain
8 lb/ft
Observed Horsepower Test Range
7 - 17 Hp
Observed Torque Test Range
6 - 12 lb/ft
Old Feb 22, 2004
Boosted2k2's Avatar
Boosted2k2 should not be trustedBoosted2k2 should not be trusted
I've never heard about it. All it does is adjust the MAP and IAT voltage to trick the ECU into thinking it's pulling in more air at a colder temperature, so the injectors deliver a little more fuel. I'm assuming it would work, but it's not tunable, and you need to actually trust the company to believe that they set it up right for each of the apps on their site. As far as I can tell, it could be just as good as a Jet chip. It works on the same basis as some other engine management systems do, but without the tunability.
If it was truly setup right, and the factors worked good... the price can't be beat. But again, I don't know the company's reputation.
Old Feb 22, 2004
czechcivic's Avatar
czechcivic is an unknown quantity at this point
hmmmm intresting
Old Feb 22, 2004
blouisgod's Avatar
Life Begins > 6800rpms
Be the guineau pig for the site and tell us how it works out.
Old Feb 22, 2004
INCivic's Avatar
INCivic is an unknown quantity at this point
Old Feb 22, 2004
abmerop18's Avatar
Jam out with your clam out.
sounds like something he just put together with some parts from radio shack. i doubt it is any more effect than those "+20 hp" resistors sold on ebay to trcik your intake into thinking there is more colder air.
Old Feb 22, 2004
Boosted2k2's Avatar
it is like that in some respects. But it also works on the MAP sensor. The ebay junk is for the IAT (which makes little difference). The MAP sensor voltage determines a lot.
h4ldol
Apr 24, 2017 08:16 PM
260000milesgoal
Sep 25, 2015 07:41 PM
blward6
Sep 16, 2015 05:32 PM
Dave Brabant
Sep 10, 2015 06:48 PM
Bricoleur
Sep 9, 2015 12:23 PM
