Sponsored by:
Sponsored by: CARiD
Automatic to Manual Swap
Old Dec 28, 2003
ricergribbs's Avatar
ricergribbs is an unknown quantity at this point
Question Automatic to Manual Swap
ok so i have a 2001 honda civic lx automatic. i plan on converting it to a manual this summer. unfortunately i still need to find some parts, for instance: the hydrolic clutch pedal assembly with reservoir. i also need the interior manual shifter assembly with all the connections. and if possible a shifter cable (from what ive heard the 7th gen uses a cable instead of a solid linkage). if someone could list where i could find this and for how much id be very appreciative. also, if you know where i could get the actual manual transmission for less then $300 then please post that too. thanks to all.
Old Dec 28, 2003
dirtySAMURAI's Avatar
I log in from time to time
search. a member has already done this, so it's best you find that thread and PM him.
Old Dec 28, 2003
Si2NV's Avatar
I plan to do the same this summer but I think it'll cost more then $300
Old Dec 29, 2003
ImportRacer2123's Avatar
K20 Member
i bought my entire motor for $400 and im getting the Pedal Assembly, Clutch master cylinder, cluster for about $140 shipped right Geoff?
and then you also need a subframe, dash wire harness, engine wire harness, tranny mounts, motor mounts. The wire harness themselves cost around $100 each. Im hoping to spend total about $750 for this swap. your best bet is to shop around and look for a complete motor tranny and ecu with all the extras don't but "just" the tranny and think you can just swap the linkage in and tranny and hook up the pedals because there is alot of tiny little stuff you need too.
Old Dec 29, 2003
Elite's Avatar
Elite is an unknown quantity at this point
I feel so proud that I did something that someone actually wants to do and provide and help people with the installation
Old Dec 29, 2003
go02civic's Avatar
go02civic is an unknown quantity at this point
i think i will just stick wit my auto. ........hehehe
Old Dec 29, 2003
K20 Member
Here is just a tranny.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33733
Old Dec 29, 2003
Master's Avatar
Banned by Admin
also look around at salvage yards, I am sure they would let you go in and pull out a tranny for cheap.
97-DX-Lover
Jun 14, 2015 06:07 PM
cruisers10
May 12, 2015 10:46 PM
oneheadlight
Apr 29, 2015 11:30 PM
McD
Apr 22, 2015 05:28 PM
SgCivic
Bolt-on Engine Performance
Nov 15, 2001 07:31 PM
