V-tec Indicator!!!!!!!
For everyone who wants to know when your V-TEC kicks in. Well here you go. It even changes color. Coming from Japan. Who's gonna be the first to run and get it?
-Chicohonda02
V-TEC INDICATOR FROM JAPAN
-Chicohonda02
If you do a search or even look into the DIY section, you can make your own for less than a $1. I did, haven't had a single problem yet. And my light takes up much less space than that thing lol. Nice find though.
Search and Learn
I as well did the diy for the vtec engagement light. I encountered something interesting. The diy is perfect but it can be even easier but it will cost about $1.00 more than the original. It is simple really. Instead of soldering in resistors you can get a 16 volt led from radio shack for about 85 cents more. But as the original diy states the light will be really bright. Also the reason you use a 16 volt led is because your car runs off a 12volt system but the alternator can spike current up to 14.8 volts if I remember correctly. But there you go, so if your not good at soldering there is a quick fix for you!
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
pilebuck13
Sep 21, 2015 10:45 PM
