Sponsored by:
Sponsored by: CARiD
FS: Apex'i Tach
Old Nov 24, 2003
whitegolf's Avatar
whitegolf is an unknown quantity at this point
FS: Apex'i Tach
I have an Apex'i rpm guages still in box (max) is 12000rpm and is 120mm wide, new conditition asking $250, got pic if anyone interested
the info is here
This 120mm EL Tachometer features real-time 30-second needle playback, peak-hold, two-stage adjustable warning, and seven-way dimmer adjustments. A'PEX engineers incorporated a 16-bit CPU to provide fast and accurate readings in 1000 step increments. The unit has the capacity to measure up to 12,700 RPM on engines with 1 to 10 cylinders. A'PEX engineers also designed the unit to be thin and compact for installation in tight spaces.
Old Nov 24, 2003
CarbonFly's Avatar
post in Marketplace.
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
NROD315
Sep 23, 2015 03:46 PM
MamaBear2015
Sep 15, 2015 09:35 PM
sam31444
ECU Fried
Jul 20, 2015 08:31 AM
