new exhaust bolts?
Old 11-20-2003
runner1738's Avatar
new exhaust bolts?
When i tried removing my exhaust header i stripped the bolts, and i wasnt able to install my dc ceramic coated header at the time, but i was thinking about trying again but i wanted to get new bolts in case is this them
seems a lot but is it worth it and what i need?
edit: sorry the link doesnt take you all the way there just click civic ex 2dr - exhaust- exhaust bolt , that should be it
Old 11-20-2003
SuperMODrizd
C2i0v0i1C's Avatar
if im correct, its not a bolt its a nut, now if somehow u stripped the threads on the bolt which i do believe comes out the block then ur really up a creek, now that its stripped u should worry about getting it off more than finding a replacement
Old 11-20-2003
runner1738's Avatar
on the top portion of the exhaust header i can get those but the bottom one to get the heat shield off i couldnt get off ive heard people applying heat and other maybe i just need to try a different wrench or extension, but i think im going to have it installed the same time i have my exhaust done, i just wasted sure if i should get new bolts for when it is off
Old 11-21-2003
Eightball's Avatar
Eightball will become famous soon enoughEightball will become famous soon enough
I had the same problem with the one on the heat shield so just left it on. The heat shield is bolted to the header so it doesn't matter.
Old 11-21-2003
runner1738's Avatar
so when i finally change them should i put new bolts on?
Old 11-21-2003
IronFist's Avatar
Read my hp header install DIY. I had a hell of a time getting the bottom bolt holding the heat shield to the header off. I had to take it to a shop and have them use a blow torch on it to help loosen it. Maybe something in my DIY will help.
Old 11-21-2003
runner1738's Avatar
yea ive read the diy and tried wd40 and so forth but nothing seemed to work, but i was just worried if i got it off that i wouldnt be able to put it back on, thats why i was curious if i should get new bolts? should i and are those them?
Old 11-21-2003
blustrek01's Avatar
blustrek01 is an unknown quantity at this point
you shouldn't have to get new bolts if all you are having problems with is the bolt that holds the heat shield on. you won't need the shield if your putting on a dc header. put a little *** into it. hahaha j/p. good luck.
Old 11-21-2003
IronFist's Avatar
Dude I recommend taking it to a mechanic if you can't get that one off.
The heatshield does not work with aftermarket headers.
But you might want to save all the stuff in case you go back to stock to sell you car or whatever.
cukaracha
08-27-2015 02:02 AM
PierrePierre
08-12-2015 02:42 PM
Kcpowerhouse
08-01-2015 06:55 AM
protoCall7
Bolt-on Engine Performance
07-26-2015 07:41 PM
Theshwartz35
07-17-2015 11:13 PM
Quick Reply: new exhaust bolts?
