Sponsored by:
Sponsored by: CARiD
Transmission Fluid
Old Oct 28, 2003
facetus's Avatar
facetus is an unknown quantity at this point
Transmission Fluid
Just need to know what type of tranny fluid to use for 01 A/T Tranny. I have amsoil atf to put in but i lost my manual and what to make sure its ok
The Amsoil is rated for the following:
Dextron II,III
Mercon, Mercon V
ATF+ - ATF+4
Could any one tell me what the honda fluid is rated
thx, facetus
Old Oct 29, 2003
Voiceofid's Avatar
End Bringer
Re: Transmission Fluid
Dextron II,III
Mercon, Mercon V
ATF+ - ATF+4
thx, facetus
you have to use honda atf, or else it will corrode your transmission, according to a honda tech i talked to
i put shell dextron iii in it, and i was forced to flush it all back out and put in honda atf(about 4 dollars a quart)
edit: i know the honda tech wasn't bsing me, because he is a masters, and he told me what other liquids in the car can be after market
power steering and atf MUST be honda or aftermarket especially designed for honda
coolant and brakes can be any, but no dot 4 brake fluid if you have abs
Old Oct 29, 2003
SMURF_KILLER's Avatar
SMURF_KILLER is an unknown quantity at this point
now I know and knowing is half the battle.....GIJOE
Old Oct 29, 2003
jblayz1's Avatar
jblayz1 is an unknown quantity at this point
Re: Re: Transmission Fluid
i was told the same.
Old Oct 29, 2003
Voiceofid's Avatar
End Bringer
Re: Re: Re: Transmission Fluid
but some of the stuff you don't have to, according to the user manual, everything have to be honda stuff x-p
OptimisticWay
46
Oct 15, 2015 02:16 PM
AirJordan613
General 7th Gen
Aug 2, 2015 08:55 PM
Q-Bert
Jul 19, 2015 09:09 PM
srtlat
Jul 17, 2015 11:53 PM
Jul 12, 2015 11:54 AM
