Sponsored by:
Sponsored by: CARiD
making paint last?
Old Oct 23, 2003
jwalker87's Avatar
Bodacious Member
jwalker87 is an unknown quantity at this point
Question making paint last?
I painted all my interior trim pieces red to match my exterior (even did the whole center console, the one that goes around the shift boot and e-brake), and it looks real nice. The only problem is, it's not very durable. I'm very careful, but if I accidentally scratch something against it (not even hard), it makes a big scratch. I'm just looking for a way to make the paint harder/more durable. It has a clearcoat on it, and that helps, but there has to be something else I can do. And no, I can't bake it to harden the paint....the paint is on plastic! Thanks.
Old Oct 24, 2003
jwalker87's Avatar
Bodacious Member
nobody knows any way?
Old Oct 24, 2003
tinman's Avatar
tinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nicetinman is just really nice
There are plastic paints that DYE the plastic. Since dye soaks into the plastic itself, it won't scratch off. Other than clearcoat, not much will help normal paint. It also takes time for the paint to fully cure.
Old Oct 24, 2003
02civicpimp's Avatar
02civicpimp is an unknown quantity at this point
on the paint issue....... you used primer right???? i messed up quite a few times when i painted the piece around the radio, and just kept sanding and primering and sanding and painting and then i finally got it the way i wanted, so i clearcoated it.. it is really smooth, (the finish) and i havent got any scratches on it yet, and i have alot of girls in my car, trying to dj my ****(their long fingernails) so if you keep coating it, it might help..... only a suggestion though, b/c i ended up doing it this way b/c when i paint, i tend to put heavy coats on it and mess it up.
Old Oct 24, 2003
HustleLikeMOFO's Avatar
HustleLikeMOFO is an unknown quantity at this point
i dunno too much about paint but i guess if would work the same way car paint works, u just need that clear coat on top of the paint and it wont scratch that easily
Old Oct 24, 2003
jwalker87's Avatar
Bodacious Member
i did the same with my radio trim...its reeeeal smooth. I scrubbed it with MEK too to get rid of those little sparkly things. Anyway, I did prime it, and I like the way it looks, I was just wondering if there was a better way to protect it. I think I'll stick with this unless something gets scratched. They're such a pain to take off and re-install, especially the door handle surrounds...
Old Oct 24, 2003
SMX's Avatar
SMX
SMX is on a distinguished road
Try this:
http://www.eastwoodco.com/itemdy01.a...&Dep_Key1=InEx
and this
and this
http://www.eastwoodco.com/itemdy00.a...66+Z&Dep_Key1=
Pick whatever color you need...
Prep, prime, paint. Follow the instructions and it'll adhere well.
Old Oct 24, 2003
jwalker87's Avatar
Bodacious Member
sweet. But I'd have to strip off the old paint, right? ehh..... And how would I know that it would match if I buy it online?
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
usajags84
15
Aug 19, 2015 03:12 AM
Jesus.
17
Jun 14, 2015 10:06 AM
dbagaus
Jun 10, 2015 09:29 AM
