Sponsored by:
Sponsored by: CARiD
need help installing an indiglo emblem
Old Oct 7, 2003
bspol's Avatar
bspol is an unknown quantity at this point
i have an indiglo emblem i need to install on my trunk.....i want to wire it to my brake lights too......i was wondering if anyone had any instructions on how i can do this? thanks
Old Oct 7, 2003
TeLLy's Avatar
Yes, it's an Acura EL
Just use self-tap clips to splice into the third brake light wires. Match the black wire on the emblem to the ground wire on the third brake light, and the red to the power wire. Done and done.
Old Oct 7, 2003
bspol's Avatar
did you have to drill holes to run the wires through, telly?
Old Oct 7, 2003
smoke4's Avatar
The Dude
if you take off the existing 'H' there should be two holes there.
Old Oct 7, 2003
TeLLy's Avatar
Sorry i was in a rush - yeah you can just run the wires through existing holes. Then just auto-goop or double-sided tape it on.
Old Oct 8, 2003
DroppIN808's Avatar
DroppIN808 is an unknown quantity at this point
hey bspol when you install it post a pic, i wanna see what that looks like.
Old Oct 8, 2003
Connie's Avatar
Most of the aftermarket emblems come with stickystuff already, I wouldnt use tape on the paint, autogoop would work though. The main problem is you have to run the wires so they don't get in the way and they are long enough when you open your trunk. You have to run them down the side into one of your taillights, after that it is easy. Please post pics, I might be doing this also.....
Old Oct 12, 2003
bspol's Avatar
my indiglo emblem's wires are too wide for the two holes that are already there, so i guess i'll have to drill new holes.....has anyone else had to do this??
Old Oct 12, 2003
gotti's Avatar
too wide? wth kinda gauge wire are u running, 10?!?
Old Oct 12, 2003
If you drill, just be sure to use touchup paint around the holes and let it dry overnight. This will prevent rust.
Old Oct 13, 2003
bspol's Avatar
nah......my wires will fit through the holes but the distance between the 2 wires on the emblem is wider than the distance between the 2 holes that are already there
Old Oct 13, 2003
ImPulse's Avatar
any pics of this? Illegal?
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
