Sponsored by:
Sponsored by: CARiD
oxygen sensor (s)??
Old Oct 1, 2003
civic-king's Avatar
civic-king is an unknown quantity at this point
oxygen sensor (s)??
hello.
i just got my header for my 02 LX.
the header is for a EX. (bought)
i know i have to weld an extention onto my stock pipe, and drill a hole for the o2 sensor.
now does anyone know if the LX has more than one o2 sensor?
i think it has two.
what shouls i do about the other sensor?
is there a o2 simulator that is for the 02 civic?
Old Oct 1, 2003
robbclark1's Avatar
Retired suspension supermod.
yes it has 2 o2 sensors and yes you can get a simulator
Old Oct 1, 2003
civic-king's Avatar
i heard from a friend that you can take the signal wire, and splice a 100K ohm resistor in. it disrupts the signal to produce optium power without setting off any engine codes. what do you think?
how does a 02 sim. work?
where do you get one?
i have a cat. it's just going down the line and i don't want to tap it in(o2 sensor) because i'm lazy.
Old Oct 1, 2003
C2i0v0i1C's Avatar
SuperMODrizd
just make another hole and weld the second on in as well, imo its much easier to just weld the bung in and screw the thing in there than to mess with the electrical wiring and crap, one is before the cat and one is after the cat, just go in the same sequence
Old Oct 1, 2003
civic-king's Avatar
ahhh....
the lazy way:
xxxxxxxxxxxxxxxxxxxx.com
humm.....
no.
well i can't figure out how to post this site.
they are out there......
$49.99
it'll be easer this way.
Old Oct 15, 2003
fennel123's Avatar
fennel123 is an unknown quantity at this point
yo. im am getting HP headers with high flow cat and Apexi WS exhaust. do i need o2 simulators? if so, where can i buy them?
Old Oct 15, 2003
Novaz3's Avatar
Novaz3 is an unknown quantity at this point
you have a O2 Sensor already, its located on your Catyltic Convertor. If you are getting a Aftermarket exhaust there should be a slot for you to install the O2 Sensor
BootyDo
Jun 21, 2016 03:45 PM
carid
Nov 7, 2015 01:46 AM
Green02civic
Jul 27, 2015 10:48 PM
mistermenphis22
Jul 13, 2015 04:43 PM
CivicsClass101
Jul 9, 2015 11:14 AM
