Sponsored by:
Sponsored by: CARiD
Tranny Cooler
Old Aug 30, 2003
EnProceso's Avatar
Tranny Cooler
i'm gonna need a tranny cooler pretty soon, how many of you know a lot about them? i was think of a TCI tranny cooler or B&G tranny cooler . i'm assuming they are universal fit, if not please let me know so i dont buy it, lol. does anyone know where i can find JMO tranny cooler?? i cant find it anywhere!!! i see it on their site but it doesnt look like they sell it directly. and if you have to recommend please do so.
Old Aug 30, 2003
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Go with the B&G cooler and I'm 99% sure that they are universal fit.
You'll love it!
Old Aug 30, 2003
flotsamm's Avatar
Did you just get a new higher stall torque converter installed or do you plan on towing? Most of the time the stock tranny cooler thats built in to the radiator is sufficient. If your constantly putting your tranny under heavy loads then a additional cooler is a good idea. If your really concerned about tranny temp, perhaps consider installing a temp guage. When I installed a street/strip tranny(good for up to 450HP/450TQ) in my truck with a high stall torque converter I had to get an additional cooler installed for protection. I also wanted to monitor my temps so I installed an Autometer tranny temp guage and inline sending unit.
If I had to go with the two you mention, I'd go with the B&M LPD(low pressure drop) stacked plate style. Theyre tougher and allow cold fluid to bypass until warmed up. Tru Cool and Hayden a few other companies make LPD coolers also. Hayden is one of the more recognized names, they do alot of OEM stuff for car makers.
Also keep in mind that over cooling isnt good either. When the fluid is cold, its thicker and doesnt flow as well. Slow flow means parts arent getting lubricated as quick. The LPD style coolers are suppose to aleviate this problem. Hope this helps.
Old Aug 30, 2003
EnProceso's Avatar
should of mentioned in the 1st post, i'm getting the tranny cooler cuz i'm getting a turbo, does that change your suggestion or still go with the B&M LPD?
Old Aug 31, 2003
flotsamm's Avatar
I'd still go with a LPD style.. that turbo is going to work your tranny pretty good I suspect. The more protection the better in your case.
mistahlorax13
21
Nov 18, 2015 12:47 PM
Whitexj
Sep 30, 2015 02:04 AM
jackoncruzpr
Sep 29, 2015 07:59 PM
speedlever
Sep 24, 2015 07:18 PM
dantheman42
Sep 4, 2015 01:10 PM
