Sponsored by:
Sponsored by: CARiD
Silencer question
Old Aug 17, 2003
agungmeth's Avatar
agungmeth is an unknown quantity at this point
Silencer question
Hi,
I just curious...Is it Ok If I am using the silencer into my muffler in the long period of time such as out of town?
Old Aug 17, 2003
Mr.Modify's Avatar
you no like the vrooomM!!!!!?
Old Aug 18, 2003
joski's Avatar
MmmMMm.. I smell boost!
joski will become famous soon enough
I don't like the vroom.. I want a cat-back for the slight bit of gain but I'd just leave the silencer in all the time.. Im not sure if the silencer takes away from the "gain" that the exhaust were to give. If that were the case, I'd live it in all the time then take it out when need be
Old Aug 18, 2003
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
silencer takes all the high end away ... I think.
Well, if you do plan to use the silencer for extended periods of time, be sure to put it in, then reset your ecu.
Old Aug 18, 2003
joski's Avatar
I'd have to reset the ECU every time its put in or taken out then?
Old Aug 18, 2003
wonderz's Avatar
wonderz is on a distinguished road
silencers takes a bit of high end away, but it also gives a bit back to the low end.
also can you tell me the reason why you need to reset ecu for exhaust install? i personally don't think you need to, the only reason for intake and ecu reset is so it will know how to mix the fuel and air mixture. but with exhaust, there is no sensor behind the cat.
Old Aug 18, 2003
01civicboi's Avatar
01civicboi is an unknown quantity at this point
you can leave it on as long as you want. I've had mine on for about four months straight now
Old Aug 18, 2003
agungmeth's Avatar
What's the ECU stands for?
Old Aug 18, 2003
wonderz's Avatar
electronic control unit if i am not mistaken...it basically is the computer for your car
Old Aug 18, 2003
Tshroom's Avatar
Tshroom is an unknown quantity at this point
you have to reset the ecu after install of CAI????
I know I didnt.
Old Aug 18, 2003
agungmeth's Avatar
Where's ECU took place?
Old Aug 18, 2003
wonderz's Avatar
I know I didnt.
you never had to reset the ecu, since our ecu adjust by itself later anyways...
Old Aug 18, 2003
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
well ... I suppose you don't really NEED to reset the ecu after you install an exhaust ... but I believe it has something to do with backpressure ... *shrug*
um ... well, actually, you don't need to reset it even after an intake or header ... it will just set itself automatically ... eventually. But it would be easier to reset it ... so you can have the ecu already know a good air mixture setting.
Old Feb 27, 2004
lid6662's Avatar
lid6662 is an unknown quantity at this point
HaS any one heard or read anything more on silencer
Power wise if it makes any diffrence for our 1.7??
Talk about bringing an old thred back
JMKendrick
Sep 16, 2015 06:17 PM
junkyardguy
Sep 2, 2015 06:07 PM
USCGBM
Aug 12, 2015 04:22 PM
