Sponsored by:
Sponsored by: CARiD
exhaust burning kit, how to fix??
Old Aug 7, 2003
slicksivik's Avatar
my magnaflow is burning my xenon kit and i put the kit higher up so it wont burn it and i have lower hangers on my exhaust already, how do i keep it from burning it? also, is double sided tape gonna be able to keep the kit on my car?
Old Aug 7, 2003
Kung's Avatar
Kung is an unknown quantity at this point
Damn, your hangers are lower and your kit is higher and your exhaust is still burning your kit. I dont know what else you can doe except take it to a muffler shop and have them bend you exhaust down somemore.
As for your other question, if you get the heavy duty double sided 3M tape, then yes it should be sufficient to hold your kit on.
If you are really worried about it you can always drill small holes, but if you follow the preping directions for the double sided tape, your kit should stick on fine as long as you make sure the fitment is correctly done.
Old Aug 7, 2003
IDQcivic's Avatar
IDQcivic should not be trusted
I have the OBX exhaust and the Xenon kit, I used some longer hangers and have no problems at all...
Old Aug 7, 2003
xtiszx's Avatar
Cracka
xtiszx is an unknown quantity at this point
makes me wonder if something is wrong, my obx catback , the tip of it touched the bumper, and did nothing to it,
is the car running hotter then normal?
Old Aug 7, 2003
RedDragon333's Avatar
the only way to fix the problem is to lower the exhaust more or maybe extend it outward a little to allow the gases to expel then cool. I would try lowering it more then maybe moveing it outward a bit
7thgensurvivor
38
Aug 29, 2015 11:50 AM
Supramk3
Jun 11, 2015 11:13 AM
zaboomafoozarg
May 30, 2015 09:21 AM
Supramk3
May 11, 2015 07:55 PM
supercivic01
South
Nov 30, 2001 11:27 AM
