Sponsored by:
Sponsored by: CARiD
Clutch.. AGAIN
Old Aug 1, 2003
BatMan's Avatar
BatMan is an unknown quantity at this point
Clutch.. AGAIN
If i got a sports clutch put in my civic... would that make it a shorter distance????? cus i talked to sumone and he said he thinks thats what im lookin for.. JUSS wana make sure though... and if thats what makes the distance shorter... WHATS A GOOD CLUTCH BRAND cuss i dunt no ANYTHIGN about clutches..
alrite thanks
Old Aug 1, 2003
nookiemonster's Avatar
RESIDENT ROTOR HEAD
nookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of lightnookiemonster is a glorious beacon of light
Okay, basically the clutch is what engages and disengages your transmission. IF you have heavily modified your car, then you're going to want to get a more heavy duty clutch as your stock one will eventually go out. I'm not sure what you mean by shortening the distance, but the clutch doesn't change any differences. It usually changes where and when your clutch will "grab" or engage your transmission or drivetrain. Basically you can get a clutch from ACT. or there are other brands, but ACT is the best that I know of. You can get a variety of clutches, from three puck to eight puck I think. The higher the stiffer your clutch will be. I recommend getting a three unless you're into some serious heave drag racing. I hope that answered your questions about clutches. As far as shortening your distance, I suggest getting a short shift adapter or short shifter. Do a search, and you can learn a little more about them.
Old Aug 1, 2003
BatMan's Avatar
WAIT.... i thought a short shifter made the Shift ****.. the one that changes gears shorter... ?? is a short shifter for the clutch.. or the stick in ur hand?????
Old Aug 1, 2003
SwtpntsDEPLOYED's Avatar
SwtpntsDEPLOYED is an unknown quantity at this point
a short-shifter is for the "stick in ur hand", not for ur clutch
Old Aug 1, 2003
robbclark1's Avatar
Retired suspension supermod.
If you don't know anything about clutches, then why do you want one??? Do a google search for clutches to see what they do. Basically when you depress the clutch it seperates the engine from the transmission so that you can shift to the next gear without ruining the transmission. There are clutchs that can take more abuse for turboed or nitrous applications or racing. There are also lightened flywheels that go along with the clutch.
ACT, Clutchmasters, Centerforce, and excedy make good clutches.
A short shifter has nothing to do with the clutch. A short shifter will change the shift point inside the car by changing the distance between the shift cable and the shift pole. It is for faster, shorter throws so that youc an shift at a better pace when racing rather than the long mushy throws the stock shifter has.
Again, please search.
Old Aug 1, 2003
BigDaddyHonda's Avatar
BigDaddyHonda is an unknown quantity at this point
Okay, I went back and read your first thread to try to figure out what you want. All you are trying to do is get the clutch pedal on your Civic to engage about 2"-3" after you push it in instead of having to push it down almost to the floor right?
Forget about spending $300 to $500 on a clutch. Our Civics have self-adjusting hydraulic clutches, but as someone already said in the other thread, there might be a way to adjust the play in the pedal (I have an auto - I can't look).
It costs you ZERO to go ask the Honda dealer if they can "adjust the clutch pedal so it will engage sooner." That is Step #1 so let us know what they say.
Old Aug 1, 2003
Tiki's Avatar
Tiki is an unknown quantity at this point
Exedy and act make good clutches i have and exedy for my 91 crx si and its great
Old Aug 1, 2003
aki's Avatar
aki
aki is an unknown quantity at this point
Getting an aftermarket clutch will do nothing to shorten your distance, like Big Daddy Honda said. It will just make the clutch pedal stiffer.
If you want less distance, you'd have to mess with the pedal itself, though I have no clue what would need to be done. It won't be easy, and it won't be worth it.
Compared to other manual cars I've driven, our distance is pretty short. It's not that long, its pretty average.
-Aki
hondarider17
Sep 17, 2011 12:03 PM
CIVICSHABBYCHIC
Aug 4, 2011 11:44 PM
chopper202
May 20, 2007 05:57 AM
scsGrumPyDriveR
Jun 13, 2002 10:26 PM
