Sponsored by:
Sponsored by: CARiD
oxygen booster?!
Old Jul 31, 2003
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
oxygen booster?!
Has anyone heard of this product? My friend has it on his infinity and he says it boosts crazy mileage...he probably exaggerated the "crazy" part but it might do something. It is a annodized cylindrical piece with some kind of mesh in between to suck in more oxygen along with the tubing from the engine's combustion chamber. He says that since our cars recycle the oxygen to recombust it a second time, you hook up this piece to that tube and it will suck in fresh air into the combustion chamber to be recombusted, thus giving more mileage and maybe some hp. I didn't know what to believe. anyone got ideas? i suck at describing cause i dunno which tube does what. lol
Old Jul 31, 2003
robbclark1's Avatar
Retired suspension supermod.
You mean this thing?
http://www.gp2000.com/
I am not sure if it will work. I have never heard of it before. It seems like a breather for the intake manifold. when it draws in some of the exhaust to be used again, it is losing oxygen. This thing allows that used exhaust to escape before it gets back to the intake manifold, thus only using air that has not be used at all while giving it more clean air.
Old Jul 31, 2003
xtiszx's Avatar
Cracka
xtiszx is an unknown quantity at this point
sounds like a good idea
the site says this about it
GP2000a Ceramic Oxygen Booster :
I. Functions:
1. Increase engine power output 8% ~ 15%.
2. Reduce exhaust emission 18% ~ 75%.
3. Eliminate carbon deposit.
4. Lower the engine knocking and
irregular shaking.
5. Improve engine poor start and engine stall.
6. Smooth the shift hesitation of
auto-transmission.
Old Jul 31, 2003
§C§H§O§C§O§B§O
thnx rob! that is exactly it!!! my friend doesn't know wth he's talking about then. Seems like it does the opposite, by letting exhaust fumes escape instead of sucking in more air. O well...anyone have one o these and knows if it works?
Old Jul 31, 2003
§C§H§O§C§O§B§O
Quote from site:
1. The intake manifold draws incompletely combusted gas from cylinder block via PCV check valve and purging hose (or Positive Crankshaft Ventilation hose) into combustion chamber to conduct second combustion in order to save fuel and reduce exhaust emission.
However, the purged gas, which has been combusted once, does not contain sufficient oxygen. Therefore, we place the GP2000a in a position to supply the second intake with extra oxygen. The purged gas drawing into combustion chamber hence contains higher oxygen ratio. This results better combustion and increases combustion efficiency.
Old Jul 31, 2003
aki's Avatar
aki
aki is an unknown quantity at this point
I wouldn't trust it. The air pressure inside the intake manifold will be greater than the outside air because it has the normal air in addition to the recycled fumes. If anything, it would only expel the exhaust gases without letting in any new air. Unless that thingy they sell has some kind of mechanism to suck air into intake manifold, there's no way its going to give new air. Reminds me of the electric turbo.
-Aki
Old Jul 31, 2003
civic-king's Avatar
civic-king is an unknown quantity at this point
hey, the electric turbo is sweet!! it flows 3X the air into the intake...sounds like an electric supercharger to me......but whatever!
they are only like $100 or somthing.......sweet!!
Old Jul 31, 2003
§C§H§O§C§O§B§O
man, you are either miss-informed, the scammer mastermind himself, or just down right stupid. If you have one o those electric turbos, your just .....
i'm not even gunna go there...someone else can finish up my sentence
Old Jul 31, 2003
cwick187's Avatar
cwick187 is an unknown quantity at this point
Dude!!! Do you realize who you are talkin' to??? He's the "Civic-King" Bow down to him you peasant!!!
Old Jul 31, 2003
§C§H§O§C§O§B§O
hahahahahahahahhaahah phat phucking chance !!!
^_^
Old Jul 31, 2003
Mags's Avatar
will you make out with me
Mags is an unknown quantity at this point
Maybe he was being sarchastic? Hopefully.
Old Jul 31, 2003
RedDragon333's Avatar
heres my bow
Old Jul 31, 2003
cwick187's Avatar
Old Aug 1, 2003
YS's Avatar
YS
YS is an unknown quantity at this point
do you know where can i get it??? i want to try it if the price is right
Old Aug 2, 2003
opto_isolator's Avatar
Man, this thing sounds a lot like snake oil.....Wtf are they talking about? The broken engrish is hard to understand.
Old Aug 2, 2003
MatrixShark's Avatar
MatrixShark is an unknown quantity at this point
My response to gimmicks like this is as follows:
If it is such a simple and brilliant idea, then why don't the engineers at Honda use it?
Old Aug 2, 2003
ohmysac's Avatar
ohmysac is an unknown quantity at this point
the intake manifold is under vacuum not pressure...so this could work...
Old Aug 3, 2003
YS's Avatar
YS
I asked the manufacture for GP2000a and this is the reply:
"We Quite sorry for late reply,it's because our web system's
construction not completely yet.
GP2000a fit the HONDA Civic 6th & before but not 7th,
due to can not found the PCV Valve on the 7th's engine
(GP2000a have to installed on the PCV Valve).
Att'd installation picture for 6th & for your reference.
Sorry for your Civic can not use GP2000a,& if you're still
interesting in GP2000a & need more information,pls let
me know, I'll send it to you by mail. Thank you !
B.Rgds
Andy"
Old Aug 3, 2003
YS's Avatar
YS
Old Aug 3, 2003
YS's Avatar
YS
Old Aug 3, 2003
YS's Avatar
YS
Old Aug 3, 2003
gipperkid's Avatar
gipperkid is an unknown quantity at this point
wouldn't we put that device on the hose that connects to the intake tube and cylinder head?? im not sure i dont have a 7thgen engine to look at right now......
Old Sep 26, 2003
§C§H§O§C§O§B§O
would that work? attaching the hose to the intake return valve? or is that the wrong one?
Old Sep 27, 2003
civic-king's Avatar
no....the pcv is somewhere else on th 7th gen....
Old Sep 27, 2003
IronFist's Avatar
what's a pcv?
Old Sep 27, 2003
civic-king's Avatar
positive crankcase valve
Old Sep 27, 2003
mclean987's Avatar
mclean987 is an unknown quantity at this point
never heard of that, does it actuyally work ? $100 that cant work, how much boost can it run? anyone very tried one
Old Sep 27, 2003
OsOBooSTeD's Avatar
OsOBaNNeD
Originally posted by YS
I but not 7th,
B.Rgds
Andy"
wow they are ****ing morons.. cause ur pcv valve is located on the back of the engine right under out intake manifold
i wouldnt buy **** from them due to the fact that they are so freakin dumb.
Old Sep 27, 2003
civic-king's Avatar
if you look at their website, they won multiple awards in the us and russia for clean air stuff.
i don't think sciencetists are dumb.
the distrubitor is dumb.
h4ldol
Apr 24, 2017 08:16 PM
carid
Nov 7, 2015 01:46 AM
thaler4cuse
Sep 7, 2015 08:25 PM
Aug 13, 2015 03:44 PM
CivicsClass101
Jul 9, 2015 11:14 AM
