Issue with 07 LX Low Beams
Rep Power: 0 Issue with 07 LX Low Beams
Howdy!
I just purchased a salvaged 07 LX with 9500 miles. The car was repaired very well from what I can tell. However, one little glitch that I've noticed so far is that the Low beams will not come on.
I pulled one of the bulbs out and the filament looks good. I put a meter to all headlight fuses to check continuity and all fuses check out ok.
My high beams work, DRL work, parking lights work, interior gauge lights dim when in low beam and high beam positions. The only thing I can come to the conclusion with is that there is a short or an open somewhere. I don't have any wiring diagrams for this car and was hoping that maybe someone would have an idea or a diagram to help me hunt this lil bug down.
Greatly Appreciated!
Rep Power: 239 Re: Issue with 07 LX Low Beams
Have you checked on any recalls on that certain model...i remember having the same issue with my civic but its an 01. goodluck
Rep Power: 0 Re: Issue with 07 LX Low Beams
Well I've run a few tests, but I still can't trace the wires back as far as I'd like. Voltage to L and R fuses in the cab when switch is on is 0.00VDC. Indicating no power to the fuses. However, I also hooked my meter up directly to the connector that the bulb plugs into and tested resistence here. With the low beams off it reads .5 Ohms, when I switch it on it reads .2 Ohms. I'm at a loss here, with the switch being off and resistence getting through that indicates a short somewhere. This engine bay is pretty hard to work around in, so before I start tearing into it I need to locate a schematic, hopefully snobird can get one.
If anyone else has any ideas, Id appreciate the help =)
I imagine it's fairly close if not the same, Gonna try to block diagram this thing...a friend of mine thinks it's the switch itself, but I wouldn't see why that would be the case if the head lights indicator is coming on when I turn the switch on. *shrug*
Electrical problems am are fun :-D LOL.
The 06 & 07 should be similar.
In this circuit the common lead of bulbs is grounded and the filaments receive switched voltage. ( totally different then previous years ) But then there is also the DRL thrown into the mix.
I would also start with the long list of fuses shown.
All fuses shows continuity. However, I get no voltage on the L or R Low beam fuses. Someone was telling me sometimes in the ignition switches there is a mechanical switch that is designed to break should the ignition be broken during theft to make low beams impossible to use, so the thief has to drive around with high beams.
The car had a salvage title when I bought it (now restored salvage) and Arizona uses salvage title for stolen vehicles, so I wonder if this is also a possibility. The ignition seems to be alright so I'm not sure, just curious if anyone knows if the civic has this device?
If I bought it from a dealer, that would be feasible. But I bought it from a private seller that doesn't speak fluent English...That makes things difficult. It's my fault for not checking the lights anyhow.
Rep Power: 267 Re: Issue with 07 LX Low Beams
ahh, that makes sense. yeah, that's a bummer. did you check the relays? don't know about the mechanism you're talking about. someone else might know.
Im assuming you're using relay interchangeably with fuse? I wasn't able to locate a relay specifically. The fuse under the hood that is shared with the power windows is good. If there's another relay somewhere I haven't located it.
However, I just noticed the fuse has a 50 A and a 40A side...is there a special way to test the fuse? It doesnt look broken, but I want to make sure I hook my meter up to it correctly.
Of course if this one was blown, the high beams wouldn't work either right?
the ONLY way to properly check a fuse is to remove it and ohm through it. if you try to ohm through it while it's in the car (through the small openings on top of the fuse) you could be backfeeding through other components and getting a false good reading. for all continuity checks, you have to isolate at least one side of the circuit.
no i'm not. it may be different on the 8th gens, but the 7th gens have a fuse for power that goes to the contacts of a relay. when you turn the switch inside the car one, the relay coil energizes and the contacts close. so power goes through the relay, not the switch in the car.
that pdf diagram posted on the first page for the 06 clearly shows a low beam relay right after the fuse. it does look to be part of the MICU. if you have power leaving the low beam fuse, then the MICU might have to be replaced. if there's no power before the fuse, you've got an power source problem.
Yeah I saw the relay in the diagram, but I was assuming ( yeah I know what that does) that it was the main head light fuse rather than a relay
stryder12
06-30-2015 08:33 PM
civiccowboy
01-20-2002 06:05 AM
