Installed wrong battery
Old Jul 23, 2016
line6's Avatar
line6 is an unknown quantity at this point
2002 Civic SI. My battery was failing so I went to the local auto store and purchased new battery. They gave me the wrong model and when I connected it up, of course it didn't start and blew some fuses. I took that back and got the right model, replaced the fuses and now the gauges wont work and all the warning lights are on. It does start but I can drive it because the anti-theft won't recognize the key so it has no power.
Old Jul 23, 2016
Re: Installed wrong battery
Elaborate on this? You can drive but it has no power, or does it only run for 2 seconds then die?
Inspect every single fuse in both fuse boxes.
Old Jul 23, 2016
line6's Avatar
It starts. I can drive it but when the RPM's get up it hesitates and feels like it wants to stall.
Checked every fuse in the box under the hood and will check the fuse box under the dash and will let you know.
Old Jul 23, 2016
So after checking the rest of the fuses.....assuming there is still a problem
Does the green key symbol flash while it the engine is running?
If this were an immobilizer/anti theft issue, the engine would be killed at 2 seconds.
Sounds like a failsafe or limp home mode. Got fault codes? Does a scanner still communicate with the PCM or not?
Old Jul 23, 2016
line6's Avatar
Checked fuses under the dash and they are all good. Yes, the green key symbol flashes while the engine is running. I will have to get hold of a scanner and check the codes tomorrow.
Old Jul 23, 2016
Um, what events led up to this?
Recent work done like alternator replacement/belt replacement, or a timing belt job?
Pay attention to whether or not the thing can communicate with the computer at all.
You've kinda described some of the symptoms that can happen after someone leaves the alternator bolts loose....the loss of alternator grounding can burn out the PCM. (bad ground cables/ poor ground connections to the engine and trans can do it too)
Loss of communication is one of several possible symptoms, along with screwy gauges and multiple warning lights....
Got a relay sometimes clicking madly behind the glovebox too?
Old Jul 23, 2016
line6's Avatar
No recent work was done. Battery was old and not holding a charge like it should and it was time for a new one. got hold of a code scanner and it does not communicate to the computer at all.
Checked the alternator, bolts are tight, belts are tight. I will go through and check grounds. No relay noise either.
Old Jul 23, 2016
Reader powered up ok(?) but no communication with PCM, this is not good.
Old Jul 24, 2016
Mikeyyy's Avatar
Mikeyyy is an unknown quantity at this point
Wrong model battery??
Old Jul 24, 2016
Probably a group 51 instead of 51R. Posts are backwards and if you don't look for the + and - before connecting cables, you end up doing harm.
05Ep3k20si
Electrical
Nov 6, 2015 04:26 PM
Robert Hamilton
Nov 5, 2015 10:38 PM
dave343
Oct 31, 2015 11:39 PM
98mxz500
Oct 22, 2015 10:20 PM
R Steele
Oct 22, 2015 05:09 AM
