'07 Civic door locking issues
Hi guys, my '07 Civic (4 door) has developed a locking issue of late. When driving the doors occasionally lock and unlock repeatedly. The driver door will not remotely lock and unlock. The remaining doors will sometimes remotely lock and unlock and sometimes not. All started happening a few weeks ago. Any ideas? (The overall issues seemingly with all the locks makes me think it's not individual actuaters)
Re: '07 Civic door locking issues
It might have something to do with the inop drivers side. Look for slight movement of that lock **** on 1st unlock press, and listen close for noise. Would indicate it is getting voltage... and not a broken wire.
Any symptoms change if you manually lock, or unlock drivers door ??
If the system detects a door is unlocked, then each time you go above 9MPH it tries to relock the doors. (depends on the driver preferences settings)
Fix the broken power lock on the drivers door.
PinkCupcakes
Electronics
Jul 18, 2019 12:50 PM
timpan
May 18, 2015 07:06 AM
