Audio upgrade question
Old Mar 25, 2014
Rss485's Avatar
Rss485 is an unknown quantity at this point
I'm looking to upgrade my head unit to a double din (possibly touchscreen) unit, but I want to keep the steering wheel controls and the USB input in the center console. Any suggestions?
Old Mar 25, 2014
Rss485's Avatar
Re: Audio upgrade question
Forgot to add, its an 09 Civic EX-L. If that makes a difference.
Old Mar 26, 2014
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Crutchfield sells several different steering wheel adapters that work with most stereos. Some are direct wired, others use a remote infrared sensor to act as a remote control.
I am not sure how far the adapter connections have come but when I installed one in my 00 Durango, it required tapping into a wire in the clockspring in the steering column. They may have connectors that go into the harness now making it a low easier.
If the USB port is a direct connection then you would just switch the plug to the new stereo. If it is wired into the harness, you may have to run a new cable with a matching end to maintain the location of the port.
Old Oct 26, 2015
kingj25's Avatar
kingj25 is an unknown quantity at this point
I would also like to update my 2012 Honda Civics LX audio. I do not have Bluetooth in my car and I would like to get Bluetooth, however is there a way for me to get Bluetooth without having to install a touchscreen? I would like to keep the function in the steering wheel with the ability to change songs from the steering wheel. Also to keep the little screen that it came with as my viewer of what songs are playing once I get Bluetooth installed, so what are my options, as far keeping the function/ability to change tracks from the steering wheel and to have the little screen be my viewer for what is playing on my phone?
Old Oct 27, 2015
Mad Dog Tannen's Avatar
You can retain the steering wheel and dash controls with an aftermarket unit, you will need the right adapters/plugs to make it work though. They should be easy to find for a Civic.
sch2cm
Jul 21, 2015 09:58 PM
NoobyKid
Jul 13, 2015 07:53 AM
