Battery Issues
Old Jul 23, 2011
mmmkkk0406's Avatar
mmmkkk0406 is an unknown quantity at this point
Thumbs down Battery Issues
I have a 06 Civic Si and just had to put another new battery in my car. Counting the factory battery this is the 3rd new battery its had. So my batteries are lasting an average of 2 1/2 years. The 2nd battery was an Optima yellow and only lasted 2 years and I chose the same battery again because it was warrantied. I was wondering if anyone else has had any issues with their car going through batteries rather quick?
Old Jul 23, 2011
Re: Battery Issues
well after reading your post, yeah i understand why. the group51 yellowtops were a failure and barely lasted 2 yrs (mine hardly made it over a year before it wouldnt start the car). optima finally decided to pull that size due to overwhelming complaints and problems. they said that the size was too small to make a working optima out of. just go back to a honda battery (interstate) and you should be fine. there is no reason to burn thru batteries unless they are defective or you are driving very short distances all the time.
Old Jul 24, 2011
electric130's Avatar
Re: Battery Issues
^what gear said, and get your alternator tested.
Old Dec 28, 2011
Bowers's Avatar
Bowers is an unknown quantity at this point
Re: Battery Issues
hi, i have a 2007 civic si and my battery is totally dead after two days of being parked. when i remove the back up fuse under the hood it solves this problem, has anyone else ran into this problem. the car had a remote start installed and i removed it and the problem is still there. it has aftermarket headlights and taillights and stock sound system. any help to point me in the right direction at this time would be greatly appreciated.
Old Dec 28, 2011
Re: Battery Issues
Does it still have the original battery? That might be the first suspect.
I can't really tell you what to do with it, I have no idea what your abilities are or what tools you have at your disposal.
I would measure the drain using an ammeter (preferably a low range inductive ammeter that can measure milliamps, but a DVOM with an ammeter may work) and troubleshoot it with a wiring diagram, and some reason and logic.
15-30mA is a normal draw, more than 50mA is too much. Remember it may take up to 10-20 minutes for some control units to go to "sleep" before you can measure current draw accurately.
Here is the stuff that uses the backup fuse (Underhood box, Fuse #23, 10 Amp): Audio unit, DLC (data link connector), Gauge control module, Immobilizer, Keyless, MICU, Navi.
Water in the wiring does some amazing things too.
Don't know if that will help you, but there ya go. Hope it helps.
HiImBrandon
Jun 1, 2015 07:34 AM
ayoitzjulesdx98
May 13, 2015 08:31 PM
Dorval Andre
Electrical
May 6, 2015 02:33 PM
WLakers
May 4, 2015 06:23 PM
tylerginevan
Apr 27, 2015 12:29 PM
