2010 Civic Si Sedan - DVD headrest
Old May 22, 2010
JEsports's Avatar
JEsports is an unknown quantity at this point
Exclamation 2010 Civic Si Sedan - DVD headrest
Hi All,
I am trying to install a DVD headrest on the passenger side of my 2010 honda civic si sedan. I only need to run the wire down through the seat. How do i do that?
Thanks,
John
Old May 24, 2010
civicpapi's Avatar
civicpapi is an unknown quantity at this point
Re: 2010 Civic Si Sedan - DVD headrest
Originally Posted by JEsports
Hi All,
Thanks,
John
Typically seat have covers on them, I would check the lower back section for a zipper or velcro style, or clip and then you should be able to fish the wire down the back to the bottom. Use coat hanger and gently feed it down, the worse case is you would need to take off the back cover.
Old May 26, 2010
JEsports's Avatar
I am going to need to remove the back cover. How do i do that? Is it very complicated?
thanks
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
Linda0818
Apr 23, 2015 11:30 AM
Civicchicky87
Idle Issues
Apr 22, 2015 07:16 PM
dano2005
Apr 14, 2015 01:58 AM
aus10
Apr 13, 2015 09:26 PM
