12" sub recomendation
Old Aug 23, 2007
jrock's Avatar
jrock will become famous soon enoughjrock will become famous soon enough
I realized today that my audiobahn aw122t is blown. This is the 3rd one and I am done with them now. I have a rockford fosgate p5002 amp. I am looking for a good single 12" sub that takes around 500 rms.....any suggestions?
thanks in advance!
Old Aug 24, 2007
xd2005's Avatar
xd2005 is an unknown quantity at this point
Re: 12" sub recomendation
alpine type R's (1242 wired parallel should do nicely)
Old Aug 24, 2007
aznprid214's Avatar
aznprid214 has a spectacular aura aboutaznprid214 has a spectacular aura about
1042 is a 10". if you want, get the 12". I'm running 2 10"s right now with 500rms into each. it hits loud. I might be selling both here soon if your interested. im thinking about getting the alpine type X... it needs 1000rms =D
Old Aug 24, 2007
EastBayStuntN's Avatar
EastBayStuntN is an unknown quantity at this point
looking for sound quality, spl, both?
price range?
how much space your working with?
Old Aug 24, 2007
jrock's Avatar
i have a huge custom made vented box that I will be using.....it is the type of box made for a a jl w7....it is large.....I am looking for sound quality.....
Old Aug 24, 2007
jrock's Avatar
anyone?....this site is terrible now a days....what happened to the 7thgencivic i used to know and love?....
Old Aug 24, 2007
jrock's Avatar
I just want something that will work well with this amp.....this amp pushes like 500 rms....so i am looking for a sub that takes 500 rms....is that the right way to go about searching for a setup?
Old Aug 25, 2007
dru106's Avatar
ThE CoRRupToR
Old Aug 25, 2007
ciVictoria's Avatar
I would say JL Audio W6v2 400RMS.
Old Aug 25, 2007
jrock's Avatar
I need to figure out what this amp actually does so I can pair it with something....this is so difficult.....
Old Aug 25, 2007
Alpha 5's Avatar
Talking Re: 12" sub recomendation
To find the "Real" wattage of your amp"
Connecta volt meter to the speaker out, + to + and - to -. do this with the speaker connected.
Now turn the volt meter on and set it to AC Volts.
Now play your music. When I do this to sub amps, I like to use a bass cd and find a track that will play a constant note for about 5 of 10 seconds. By doing the constant note it will allow the voltage to stabilize and not jump allover the place.
Now that you have this number, for easy math I will say that the number is 50.
You square the number so 50*50=2500
Now you divide this by the total ohms of all speakers connected to the amp you are testing. Lets say you have a DVC sub with 2 4ohm VC's and they are ran in series. so you have 8ohms.
2500/8=312.5
Your amp was putting out 312.5 watts to the speakers when it measured 50 volts.
Here is the formula: Watts=AC Volts sq/Ohms
Here is a site that will do it for you, all you need to do is punch in a couple numbers.
http://ourworld.compuserve.com/homep...en/ohmslaw.htm
More reffrence:
http://www.the12volt.com/ohm/ohmslaw.asp
Old Aug 25, 2007
Alpha 5's Avatar
Also, is this your amp?
If so then here is what it does.
Rated Continuous Power
125W x 2 @ 4-Ohms RMS
250W x 2 @ 2-Ohms RMS
500W x 1 @ 4-Ohms bridged RMS
Using the reference above and the link in the previous post. I found out that this amp delivers just under 23 ac volts per channel.
Here is a reference page:
http://www.rockfordfosgate.com/produ...n_US&p_status=
If this is not your amp, post a pic of the label on the rear.
Old Aug 25, 2007
jrock's Avatar
no..I have the p5002 it is 500x1 but I have heard it is overrated........ I just want to get a good sub that is 500 rms I can only seem to find subs that are 400 or like 250 - 400
Old Aug 25, 2007
aznprid214's Avatar
Alpine Type R subs are 500rms.... thats should be in the range of what your looking at.
Old Aug 25, 2007
jrock's Avatar
those type r's nice?...or should i go for a perfect 12.1
Old Aug 25, 2007
aznprid214's Avatar
i mean they get pretty loud... i gotta go upgrade my big three, because I have a digital reading on myamp and when i turn it up, the voltage drops... =/ so im not even getting full power.
Old Aug 29, 2007
ryox82's Avatar
ryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to allryox82 is a name known to all
I just had MTX Audio dual 12's wired in paralell. They are 400 rms but I am running a 480 rms amp. They were just isntalled tonight and hit HARD and do well with every kind of music I throw at it. I can only imagine when they break in.
Old Sep 4, 2007
aznprid214's Avatar
just to throw it out there, but would you even consider a 10" Alpine Type X? it requires 1000wrms... =D
Old Sep 7, 2007
Str8UpCivic's Avatar
Tire Spin
Str8UpCivic will become famous soon enough
i have 2 12in pioneers nd they amazing but if ur looking for just 1 12in and dont have a price limit i would go with any JL ftw.
Old Sep 8, 2007
ryox82's Avatar
Yeah those MTX Audio's are good if you DO have a budget. The difference is they dont SOUND like a budget set up. They hit harder and cleaner than anything else I have heard around here.
Old Sep 8, 2007
dopeyboy247's Avatar
dopeyboy247 will become famous soon enough
sound quality in a huge ported box hmm..
if you want tight accurate bass (sq) get a sealed box.
Ported boxes play Louder from what I have researched in the past..Etc.
this is what I think: just my opinion
Ported = loud, big box, SPL. Etc..
sealed = tight bass, accurate bass, SQ. Etc..
You need a good quality & powerful subwoofer. Kicker Solobaric L5 or L7, Kicker Comp VR, Rockford Fosgate P3 or Power Series subs, MTX, Alpine, JL Audio, Etc.....
Research and Search the web
Old Sep 8, 2007
ryox82's Avatar
The ones I am talking about are sealed...
Old Sep 28, 2007
Andrew12's Avatar
Andrew12 is an unknown quantity at this point
Don't mess w/ the mtx subs. There's much better out there. I never saw anywhere how much you were looking to spend. Also, the RF amp is UNDERRATED. RF makes solid amps manG. Theres a couple different choices for you. Look into the Fi Audio 12" SSD or a 12" SI BM. Both of those are amazing subs for the money. LMK if I can help out any other way
ATL
badcivic2002
Oct 12, 2006 10:26 PM
nbpEMCivic
18
Apr 21, 2002 09:22 PM
FLY
Mar 27, 2002 02:31 PM
devilvtec
Feb 24, 2002 11:02 AM
StLVtec
Nov 14, 2001 09:22 PM
