Wheels, Tires & Brakes Modifications Post Wheel, Tire & Brake related modification information and/or questions here.
New look Civic hubcaps on 2006 Civic
Old Oct 30, 2022
tonybeo's Avatar
tonybeo is an unknown quantity at this point
Can anyone tell me if aftermarket hubcaps (that look like the ones for newer Civics) will fit on my 2006 Civic that has 16" rims?
Thanks.
Old Oct 30, 2022
FRSam's Avatar
Click Here
Re: New look Civic hubcaps on 2006 Civic
If you have steel wheels, then yes. I’m assuming all aftermarket hubcaps are the same and don’t mount any differently - I’ve admittedly never run them.
Old Oct 30, 2022
I prefer to paint my steelies with metallic gray - hub caps get lost
Old Oct 30, 2022
tonybeo's Avatar
I thought maybe some wouldn’t fit because when i looked at some on Amazon that were listed as for 2016 and 2017 civics and it was for a 16 inch rim but when I asked the seller if they would fit the reply I got was that they would not fit my 2006.
would there be any reason why a 2016/2017 rim would be different than a 2006 rim such that they would not work?
Old Oct 30, 2022
what type are they? The ones that just clip to the wheel or the ones that are held by the lugnuts?
the ones held by clips should fit, if they are held by the lugnuts, well, the distance from the lugnuts and wheel lip might not work depending on off-set - different for the 2016+
https://www.procivic.com/pages-honda...ide/index.html
https://www.lesschwab.com/article/wh...el-offset.html
Old Oct 30, 2022
tonybeo's Avatar
They clip to the rims…thanks
Vanguard25
Aug 1, 2009 12:34 PM
ill02civic
Jun 15, 2006 05:47 PM
trev0006
Apr 14, 2006 03:56 PM
frenum101
May 8, 2005 09:58 PM
