Cv axle transmission seal part numbers
I have a 2008 Honda Civic LX automatic 4 door sedan. I need to replace my passenger cv axle (boot is torn), and the drivers side axle/transmission seal (it’s leaking fluid). I figured I should replace the seal on both sides. Does anyone know the Honda part number for the drivers side and the part number for the passenger side? Are they different? Are they different than manual transmission seals?
Also, any advice for installing new seals? I try to press them in evenly and flush with the transmission, but they always seem to leak. Do I need to add grease to the seals? I know Honda seals have grease on the inner circumference, and the National brand do not. I know Honda brand is recommended.
Here are the part numbers I’ve seen:
91205-PL3-B01
91206-PHR-003
Thanks in advance!
91205-PL3-B01
91206-PHR-003
Thanks in advance!
Re: Cv axle transmission seal part numbers
I see 91205-PL3-A01 for the driver's side, and 91206-PHR-003 for the passenger side. Looks like both are auto transmission only. There should be grease already on the seal like you mentioned. No need to add any more.
thisguy
Aug 9, 2011 02:49 PM
