General 8th & 9th Gen Got a question or want to post but it doesn't quite fall under any other topic? Post up here!
How to start a manual without the clutch depressed
Old 12-18-2018
Aerose91's Avatar
Aerose91 is an unknown quantity at this point
I have an 06 EX and the clutch was on its last legs anyway but i let my mother drive it and now it's shot. Wont disengage, pedal has zero pressure behind it and the fork on the slave cylinder is stuck engaged. So, time for a new clutch but it's the middle of winter and I'd rather not do it till spring.
i want to get some fuel additive in there for the time it will be sitting but the car wont start now. I thought there was a clutch position switch on the pedal so i disconnected it and tried to start it with the car in neutral but it didn't work. Any way to get this thing started?
Old 12-18-2018
Colin42's Avatar
Received 1,126 Likes on 941 Posts
Re: How to start a manual without the clutch depressed
you probably need to bridge the contacts on the connector
Old 12-18-2018
Aerose91's Avatar
Clever. So the top wiring harness on the clutch pedal is the position sensor, right?
Old 12-18-2018
Colin42's Avatar
no idea, your car is newer than the one i had
how many switches do you have on the pedal? one or two?
on the older civics there was two, one for starting and the other was for cruise, and one of them is really high up
not sure what they use on the newer ones.
The switch has normally open contacts, when you push in the clutch that closes the contacts
so if you use a chunk of wire or something you can override the circuit, be careful not to mess up the connector
Old 12-18-2018
Dr Krieger of Modification
mac25's Avatar
When the clutch pedal is not being depressed the circuit is open/ clutch pedal switch open.
You need to close the circuit.
Old 12-18-2018
Prelude Owner
GolNat's Avatar
If the pedal goes to the floor then the switch is closing the circuit so the car should start. Unless the switch has gone bad then you need to jump the pins together.
Old 12-18-2018
If the pedal goes to the floor but doesn't feel like it does anything (won't disengage), see if the clutch reservoir simply ran out of fluid.
If the pedal still moves and goes to the floor, that should still let the starter safety switch operate and the starter should crank as usual.
streetglower
Transmission DIY
10-08-2014 01:14 PM
paarlberg
12-28-2010 10:57 AM
yock
16
06-17-2008 12:43 PM
civicrice
07-29-2004 09:25 PM
Getupk1d
30
06-10-2003 08:54 AM
Quick Reply: How to start a manual without the clutch depressed
