My clutch burnt?
Old Jul 28, 2004
civicrice's Avatar
civicrice should not be trustedcivicrice should not be trusted
My clutch burnt?
it doesnt start going untill halfway out. but when i slam second gear it grabs nice. im just concerned about it letting out halfway.
Old Jul 29, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
nope.. nothing is wrong.. if you are concerned with when it engages, bleed the clutch line.. the stock clutch is good for a while.. altho if you have an aftermarket one.. the clutch might engage like an inch off of the floor
Old Jul 29, 2004
FALKEN's Avatar
Civicforums Junkie
moved to the Vehicle Issues / Problems forum
Old Jul 29, 2004
Zzyzx's Avatar
Autocross Junky
Do your self a favor.... Ya know that pedal thats to the left of the clutch?? the one thats attached to the floor?? Rest your foot there when your not shifting... It will save your clutch. (I.e. Dont rest your foot on the clutch pedal when your not shifting, that causes slipage and extra wear on the clutch).
as far as when it engages/disengages.... well Performance wise you want the shortest through you can get, so if the cluch doesnt engage/disengage untill half the total throw of the clutch pedal then that means you dont need to push the clutch to the floor to shift... = speedier shifts.
Old Jul 29, 2004
CuRiOuSfIsH's Avatar
Back From The Banned!
your clutch sounds fine. WHen it gets to the point where the car takes a long time to engage, then it will be time to change the clutch. and yes, use that dead pedal, the "4th pedal".
sesi
Oct 1, 2015 02:03 PM
ThatGuy913
Sep 28, 2015 05:35 PM
speedlever
Sep 24, 2015 07:18 PM
Klame9420
Sep 7, 2015 10:03 PM
dantheman42
Sep 4, 2015 01:10 PM
