Alternative to Honda ATF
Old May 3, 2017
fcs's Avatar
fcs
fcs is an unknown quantity at this point
Any acceptable alternatives to Honda ATF? I drive past probably 10 parts stores before I get to the Honda dealer. Doing a drain & fill on 2006 Civic.
Old May 3, 2017
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
Re: Alternative to Honda ATF
Name brand (penzoil/castro/mobil) ATf is going to cost you $6-7 per quart. Honda ATF list price is something like $8. I would never suggest someone uses an universal ATF instead of Honda Atf.
Old May 3, 2017
Absolutely correct fluid is not expensive and you don't have to wonder if it's right or not.
You only need to buy 3 quarts for a single drain and fill, surely you can afford the difference.
Replacing a trans is not cheap.
Old May 3, 2017
CraigW's Avatar
The 8th gen 5AT has a great track record.
Spend a few $$ more and use OEM.
Old May 3, 2017
fcs's Avatar
fcs
Wasn't looking to save a buck, just the drive across town in traffic.
Old May 3, 2017
brags's Avatar
"Honda - tried, true & tested...!"
brags is an unknown quantity at this point
thats right has to be ONLY Honda ATF in the automatic trans using anything else
its not a maybe... You will damage the auto transmission trust me.
