2006 civic coupe lx dashboard problems
Old Jun 1, 2016
abarba50's Avatar
abarba50 is an unknown quantity at this point
So i purchased this car and the speedo odometer, rpm's and heat/cold sensor do not work. the guy said he took the car up to mammoth and had to put on tire chains. the tire chains tore wires under the hood and the dash no longer works. anyone know what wires these are? is it cheap to replace? the wires can be seen next to the front right side wheel
Sorry these images are upside down for some reason
Old Jun 1, 2016
mac25's Avatar
Dr Krieger of Modification
Re: 2006 civic coupe lx dashboard problems
If you can just try to cut out the damaged areas of the wires and solder in bridging segments.
Old Jun 2, 2016
They are pretty important wires.
Depends on what you consider cheap, and if there is other hidden damage to electronic components that you have yet to discover.
Replacing the damaged wiring harness might sound simple......until you discover how much of the car has to come apart to replace it. That little harness may wrap around both front wheels, up to the front bumper and lights, and go all the way through the firewall and into the dashboard, meaning you might have to remove the dash to reach it all.
BTDT. Not fun.
I'd probably try to splice and repair the damaged wiring, assuming it isn't corroded so bad it needs huge amounts of wire replaced. If repaired, it would have to be sealed really well to avoid future problems from exposure to the elements (water/salt).
But I like wiring work....many others do not.
Also, the plastic inner fender liner or shield is missing.
Johhny
ECU Fried
Dec 16, 2015 01:24 PM
TimsCivic04
General 7th Gen
Dec 3, 2015 02:31 AM
steve6
Nov 22, 2015 08:18 PM
redrocket87
Nov 1, 2015 07:15 PM
Hani4g
Oct 31, 2015 02:09 PM
