2007 automatic stalling when cold
Old Dec 10, 2015
gsb104's Avatar
gsb104 is an unknown quantity at this point
hi
new to the forum so HELLO
i have a 2007 civic that when cold will try to stall and if i try to rev it to pull away there is some hesitancy .
i have changed the engine coolant sensor but it still runs the same.once the engine has warmed up it runs absolutely fine.there is no engine light on and no codes
hoping someone can help.i'm tearing my hair out
Old Dec 10, 2015
Re: 2007 automatic stalling when cold
Welcome.
You in the UK/England?
Most of us are in North America, you may have different versions of the cars than we do here.
Recent air filter replaced? Airbox not sealed? Filter gasket mangled?
Bug stuck in the MAF sensor?
Too much alcohol in the fuel can make them hard to start and run bad cold...I'd expect a check engine light and a lean code if that were the case.
Old Dec 11, 2015
gsb104's Avatar
hi
thanks for your quick reply
yes i am in england.i will check those things you mentioned today
thanks for your advice
mgrantaz
General
May 2, 2022 05:40 PM
thebmillz
Electronics
Oct 2, 2015 08:38 PM
Deebo12
Air Conditioning
Sep 26, 2015 11:08 PM
charmon4815
General
Sep 22, 2015 08:00 AM
rayaan_wasty
Sep 14, 2015 02:00 PM
