2008 civic si transmission problem ?
Old Sep 20, 2015
jerry38's Avatar
jerry38 is an unknown quantity at this point
when cruising on any gear and i try to speed up; my speedometer gauge moves up (spikes) but my car still drives at the same speed. I have heard that SI
6 speed transmissions have a bad reputation. Does anyone know what's going on with my car. IT has 100 k miles, transmission clutch replaced a year ago.
Old Sep 20, 2015
jerry38's Avatar
2008 civic si....transmission or something else ?
My si has 100k miles, when i try to speed up too fast on any gear,the speedometer just spikes and the car continues to travel at the same rate of speed. I am forced to down shift in order to speed up. I had my 6 speed transmission clutch replaced a year ago. Does anyone have any ideas how i may fix this problem?
Old Sep 20, 2015
Re: 2008 civic si transmission problem ?
Sounds like your TACHOMETER spikes, not the speedometer.
Sounds like it needs a clutch. Again.
........And if a clutch only lasted you a year, it's on you.
You need to learn how to drive a manual trans car to minimize clutch wear.
HTH
usajags84
May 10, 2015 08:11 AM
Rinzlor
Apr 24, 2015 10:33 AM
Richkid23
Apr 19, 2015 12:53 PM
mugenca
Apr 16, 2015 12:15 AM
Russps
Nov 8, 2001 02:00 AM
