How to Fix Error Codes P2185, P2183, P0111, and P0128 on a Honda Civic 2006
Old 12-05-2014
HCivic2006's Avatar
HCivic2006 is an unknown quantity at this point
Hi all. I have a 4-door Honda Civic 2006 LX 1.8.
The engine light came on last week. The mechanic's computer gave error codes P2183 and P0111. I replaced the Engine Coolant Temperature sensor on top with a genuine Honda part. The engine light went away. Then today it came back on, then went off by itself, then it came back on and stayed on.
Today he got the following codes: P2185, P2183, P0111, and P0128. I did my research and these codes seem to be common for this car, but I havent found any conclusive solutions or answers as to what fixed the problem.
I found this useful: http://ww2.justanswer.com/uploads/Ho...201805_hyb.pdf. And the common opinion on the internet says it is a corroded or broken pin from the ECT #2 sensor at the bottom of the radiator, but I havent found any reports that confirmed the error codes going away after replacing the 2-pin head on the ECT #2.
Before I go ahead and replace the ECT #2 or the 2-pin head, does anyone know if this is most likely the ECT #2 sensor, the thermostat, or the IAT sensor?
I'm trying to repair this myself so any tips you can share would be muchly appreciated it. Thanks
Old 12-05-2014
Re: How to Fix Error Codes P2185, P2183, P0111, and P0128 on a Honda Civic 2006
Not sure why your post went where it did (invisible), but here you go.
I have fixed many of these.
I see you found the bulletin addressing all 4 of these codes appearing together.
Yes it will be due to ECT2, you will find either a bad sensor or leaking sensor and damaged wiring. (or a bodyshop hacked it up LOL)
You may need to clear the codes after repair.
HTH
Old 12-06-2014
HCivic2006's Avatar
Thanks ezone
do you think I may be able to clean the corrosion off of the ECT2 sensor itself or its 2-pin connector? How would you recommend I do that?
Old 12-06-2014
Remove the wire connector and inspect the harness terminals first.
I'd guess better than 9/10 were just a faulty sensor.
Any in our shop with wire harness terminals damaged usually got terminals and wire replaced to ensure a positive and long lasting repair.
Old 12-06-2014
HCivic2006's Avatar
my engine light just turned off by itself. it came on and off 4 times over the past 2 days. Could that be the result of just a faulty ECT#2 sensor or do you think it might have something to do with a faulty ECU?
Old 12-06-2014
Don't overthink this.
The PCM is damn relaiable.
Old 12-16-2014
HCivic2006's Avatar
Replaced the ECT2 sensor and reset the engine light. It's been off for over a week and 700km. So I think that might have solved the problem. Even though when I took out the old ECT2 sensor it was still shiny and looked new without any signs of corrosion on it. Didnt notice much corrosion around the 2-pin terminal/connector or the wires either.
Old 12-16-2014
So it was a simple bad sensor, internal failure. Good deal!
Old 07-29-2017
Bluefish8's Avatar
Bluefish8 is an unknown quantity at this point
Any idea of the part number for this radiator sensor and companies that make it? I am having trouble finding it
Old 07-29-2017
Any Honda dealer can get it for you.
http://www.hondaautomotiveparts.com/
Look under 'radiator'
jessicakaybby
04-20-2015 12:11 PM
CascadiaBlue
04-18-2015 09:13 AM
dooner24
04-14-2015 07:51 PM
bahena08
04-11-2015 05:09 PM
Quick Reply: How to Fix Error Codes P2185, P2183, P0111, and P0128 on a Honda Civic 2006
